Dana strength #1273821
07/24/12 12:22 AM
07/24/12 12:22 AM
campbell river B.C
mopartoby Offline OP
campbell river B.C
Anyone running a dana behind 1100 plus hp? Any issues?
Re: Dana strength [Re: mopartoby] #1273822
07/24/12 12:40 AM
07/24/12 12:40 AM
The old Mopar sponsored Top fuel, funny cars and Prostockers (not 1100 hp back then on the Pro stockers) all ran them back in the 1970 and 1980s but I'm pretty sure the top fuel guys had that much times three I'm sure the application and use will have a lot to do with how long any component last in the drive train
Re: Dana strength [Re: mopartoby] #1273823
07/24/12 01:02 AM
07/24/12 01:02 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
The dana will be fine as long as you don't need a pro gear below 4.10. even then it will be fine, it will just go thru street gears pretty quick
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Dana strength [Re: bigtimeauto] #1273824
07/24/12 10:58 AM
07/24/12 10:58 AM
gregsdart Offline
gregsdart  Offline
The rear is plenty big enough for most applications, so the materials and setup of the gears are the variables. Proper setup can mean a long or short life. I hammer mine pretty good, and I am sure the transbrake, 900 hp and 3050 lbs combined with 15 inch wide slicks really put it to the test! The 4.56 gears I have in mine have about 300 passes on them, no problems. Of all the things that can hurt a rear, the shock loads of a transbrake is tops.
Re: Dana strength [Re: gregsdart] #1273825
07/24/12 03:13 PM
07/24/12 03:13 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
Dana 60 is a good rearend for high horsepower cars. We change gears every 200 runs and inspect all other componets. We have had good luck with ours. poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Dana strength [Re: poppaj] #1273826
07/24/12 08:50 PM
07/24/12 08:50 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The only dana I have ever seen break is mine, pinion bearing fell apart and chipped away the teeth. On the other hand, I have seen about a dozen 9" ford rears spit the pinion right out of the case.
Re: Dana strength [Re: rowin4] #1273827
07/24/12 10:01 PM
07/24/12 10:01 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I beat on mine pretty hard. Had a very stought small block well over 900HP with two nitrous kits on top and did not hurt the ring and pinion. Snapped an aluminum spool but it was seven years old.
Leon
Re: Dana strength [Re: Leon441] #1273828
07/25/12 02:17 AM
07/25/12 02:17 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Upgrade to the Jana 76, it puts a 10.5" ring gear in a 60 housing. good for 8000 ft lbs of momentary torque, a stock 60 is good for around 6000 ft lbs of momentary torque....
Re: Dana strength [Re: astjp2] #1273829
07/25/12 08:21 AM
07/25/12 08:21 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We run a 4.10 Dana 60 in Donny Martiks 540"blown alcohol 65 Cornet that weights 3200 lb.
Re: Dana strength [Re: rowin4] #1273830
07/25/12 08:50 AM
07/25/12 08:50 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Say it ain't so Joe! I thought that was the only indestructable rear end in the world, I'm crushed .
