Tape or glue for metal emblem adhesion? #1273596
07/25/12 01:39 PM
07/25/12 01:39 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Ok, I am doing a cheapo Ramcharger and want to ad the power wagon emblems onto the hood. However the emblems have broken studs. I dont want to purchase new emblems and am thinking that a lot of the new emblems have adhesions tape that seems to work well. Anyone know what this type of tape is or know of a brand that works great? Or should I try some sort of glue which I ma trying to avoid.
RUMBLON
Re: Tape or glue for metal emblem adhesion? [Re: RUMBLON] #1273597
07/25/12 01:48 PM
07/25/12 01:48 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
I'm not familiar with emblems you are going to use and what kind of back they have that will have to adhere to the tape, but that 2-sided tape will stick until you saw it off with fishing line or similar. It is sold in most auto parts stores, probably 3M brand would work. Make sure you prepare the surfaces on the emblem and the car. I usually use rubbing alcohol to clean the surfaces. When you apply the emblem to the tape and the car, hold down for a minute or so until the tape sets.
Re: Tape or glue for metal emblem adhesion? [Re: RUMBLON] #1273598
07/25/12 01:48 PM
07/25/12 01:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Get the 3M double sided tape with the red liner.... Don't waste time or money on the white liner stuff....
Re: Tape or glue for metal emblem adhesion? [Re: 1_WILD_RT] #1273599
07/25/12 05:48 PM
07/25/12 05:48 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
And cleanliness is important!
Re: Tape or glue for metal emblem adhesion? [Re: RodStRace] #1273600
07/26/12 01:53 AM
07/26/12 01:53 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Problem solved, a friend had a set of ones that utilize screws that are in nice shape for $25.00.
RUMBLON
Re: Tape or glue for metal emblem adhesion? [Re: RUMBLON] #1273601
07/26/12 02:49 AM
07/26/12 02:49 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I was going to say aquarium silicone - adheres to everything, lasts, clear and trim-able, and can handle vibrations.
Ride eternal, shiny and chrome
Re: Tape or glue for metal emblem adhesion? [Re: 1_WILD_RT] #1273602
07/26/12 10:56 AM
07/26/12 10:56 AM
PA
Jack Zupan Offline
Jack Zupan  Offline
PA
"Get the 3M double sided tape with the red liner.... Don't waste time or money on the white liner stuff...."
I agree also. Have done this a number of times with good luck. If the emblem has tabs I remove them with side cutters and then use the two sided tape. They have been on one of my cars for over eight years with no problems.
