Page 6 of 25 1 2 4 5 6 7 8 24 25
Re: new Moparts fastest car list, post yours! [Re: mark_gates] #12734
10/07/04 06:35 PM
10/07/04 06:35 PM
mohnton pa
rva Offline
super gas
rva  Offline
super gas
mohnton pa
will someone put mine in,
RVA 10.64@124.50 1.49 60' 440ci 3165lbs
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12735
10/08/04 06:29 PM
10/08/04 06:29 PM
'66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle.This BAD66 is for sale, not cheap!
Re: new Moparts fastest car list, post yours! #12736
10/13/04 07:47 PM
10/13/04 07:47 PM
gregsdart Offline OP
---7 second zone ---
572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60'
valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed
---8 second zone ---
The Haze 8.02 @ 174+ twin turbo 452"
B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60'
SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor
Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only.
JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164
TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340#
"Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156
Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04
RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF
---9 second zone ---
Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG
NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph
572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car !
Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle
TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension
MR P BODY 9.47@142.5 395 ci W-2 2430#
Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142
acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137
Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89
440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID
Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid
b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99
Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH
---10 second zone---
Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A.
J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb
Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam
StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor.
daron 73 duster 10.50 et @ 127.00 sb street car
BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas
TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust
eeka440 73 Swinger 446 906's auto 10.84@124.4
85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off)
---11 second zone ---
Bubba '80 Mirada, 440 , 11.11 & 120.32, 1.58 60', 3855LBS
ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60'
TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned
Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer
LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas
aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto
w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver
440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street
493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57
68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car
Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires
6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52
topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft
---12 second zone ---
cudadan, 12.02 at 110 with a 1.58 60ft
quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4
Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
Greg J,12.466 @ 108.98 (1.764 60')69 Road Runner 3850 # w/driver, 446
JamesTait, '70 RR 440 4-spd 3.91 12.4 @ 114.04 (1.9 60')
OUTLAWD, 12.75 @ 107.5, 1.89 60', 360/727/3.23,street tires
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12737
10/13/04 10:40 PM
10/13/04 10:40 PM
1982 Rampage 2.5 turbo 16v(neon head)
Auto 10.66@132.99 1.78 60ft. 105mph eigth
Re: new Moparts fastest car list, post yours! #12738
10/17/04 08:27 PM
10/17/04 08:27 PM
an8sec70cuda Offline
a10sec70cuda, 10.55@128.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5"
CHIP
'06 GMC 2500HD LBZ Duramax
Re: new Moparts fastest car list, post yours! *DELETED* *DELETED* *DELETED* [Re: BENCHRACER] #12739
10/19/04 05:19 PM
10/19/04 05:19 PM
Hello
Mr. Tommy Tiger here
Re: new Moparts fastest car list, post yours! *DELETED* *DELETED* *DELETED* #12740
10/19/04 05:35 PM
10/19/04 05:35 PM
Marion, SC USA
69RR383 Offline
69RR383  Offline
Marion, SC USA
Welcome to the board! Sweet car. Suggest you start your own post and introduce yourself and give some specifics on that nice ride.
Re: new Moparts fastest car list, post yours! *DELETED* *DELETED* *DELETED* [Re: 69RR383] #12741
10/20/04 02:15 AM
10/20/04 02:15 AM
Thanks a lot
Here is information about me and the Beautiful Brurt.
Tommy "Tiger" Ove Björk, drag racing promoter and driver, was born in Jakobstad, Finland in 1956. He now lives in Sweden and works as a laboratory technician for Phillips 66 in Norway. Tommy "Tiger" started his drag racing career in 1978, driving a 1968 Corvette Stingray and two years later in the same class a 1970 Chevelle with a big block engine. He has raced in seven classes all told ranging from Street classes to 200 mile per hour Pro Modifieds.
Tommy "Tigers" beautiful Pro Classic 1957 Chrysler 300 C (built in Sweden) was one of the most popular race cars in the series. The Chrysler 300 C was also driven successfully for two years by European 1998 Pro Stock Champion Nicklas Andersson.
http://www.ihra.com/news/2000/july/24bjork.html
Re: new Moparts fastest car list, post yours! #12742
10/20/04 07:32 AM
10/20/04 07:32 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
Put me in the 10sec zone 10.70@125 3700 lbs mufflers
Re: new Moparts fastest car list, post yours! [Re: an8sec70cuda] #12743
10/24/04 06:19 PM
10/24/04 06:19 PM
Easton, PA
68DART360 Offline
68DART360  Offline
Easton, PA
68DART360 11.75 @ 113 1.57 60ft pump gas street tires
Re: new Moparts fastest car list, post yours! [Re: 68DART360] #12744
10/24/04 08:11 PM
10/24/04 08:11 PM
SE Nunya
Bubba Offline
Bubba  Offline
SE Nunya
Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS
Re: new Moparts fastest car list, post yours! [Re: Bubba] #12745
10/24/04 11:51 PM
10/24/04 11:51 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA
Re: new Moparts fastest car list, post yours! [Re: Bubba] #12746
10/25/04 07:41 PM
10/25/04 07:41 PM
DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA
Re: new Moparts fastest car list, post yours! [Re: gregsdart] #12747
10/26/04 02:09 AM
10/26/04 02:09 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A
Re: new Moparts fastest car list, post yours! [Re: MoparforLife] #12748
10/30/04 02:28 PM
10/30/04 02:28 PM
1986 DODGE DAYTONA 2350LBS 377 W-2 VICTOR INTAKE
1050 DOMINATOR 904 TURBO ACTION 5500 CONVERTOR
FULL TUBE CHASSIS 8.81 @ 154.24
LONG ISLAND DRAGWAY
Re: new Moparts fastest car list, post yours! #12749
11/01/04 03:28 PM
11/01/04 03:28 PM
Hey I'm new I don't know what to do please add me in
Re: new Moparts fastest car list, post yours! #12750
11/05/04 07:40 PM
11/05/04 07:40 PM
land of the free
ts racer Offline
ts racer  Offline
land of the free
1964 dodge polara b1 t/s 7.28 @187 mph
Re: new Moparts fastest car list, post yours! [Re: ts racer] #12751
11/06/04 11:56 PM
11/06/04 11:56 PM
S.L . MI
clutch Offline
clutch  Offline
S.L . MI
10.22@132.37 106.37@6.52 1.498 60
W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161
Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60
Mopartony, 68 Dart 470cid, 727, 10.89@121
fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60'
tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears...
OUTLAWD
"MOPARTS, We're bad, we're nationwide." UNLAWFL
Re: new Moparts fastest car list, post yours! [Re: clutch] #12752
11/07/04 02:29 PM
11/07/04 02:29 PM
Farmington Hills, Mich
Chuck@Best_Machine Offline
BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin
Re: new Moparts fastest car list, post yours! [Re: Chuck@Best_Machine] #12753
11/07/04 03:25 PM
11/07/04 03:25 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60'
