Detroit Truetrac Vs. Locker Limitation Q's #1273422
07/25/12 01:54 AM
07/25/12 01:54 AM
Sorrento, BC, Canada
4speeds4me Offline OP
What are their HP/Tq limitations, and which would be the better choice in a 95% street driven car...408/4-speed A-body? The price is pretty similar, so dollars aren't really a factor.
Thanks for the input guys!
2 Demons...no, not my kids!
Re: Detroit Truetrac Vs. Locker Limitation Q's [Re: 4speeds4me] #1273423
07/25/12 09:07 AM
07/25/12 09:07 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I had a truetrac in a 4200 lb dakota pick-up with a stroker 383 that was making 535 ft lbs of torque, shifted with a TKO transmission, and never had a problem with it. I prefer the truetrac over a locker because going around corners is very smooth, no ratcheting action like you get with a locker.
when you get into the throttle and "set" the truetrac, it locks up just like a locker does, but when there's very little throttle input, and/or nearly zero traction, it acts like an open diff, in fact, if you jack up the rear and spin a tire, the opposite side will spin backwards, just like the open diffs, it does this because there's no load on the gears inside the differential.
I also like the truetracs because they don't have clutches that wear out
**Photobucket sucks**
Re: Detroit Truetrac Vs. Locker Limitation Q's [Re: 4speeds4me] #1273424
07/25/12 10:18 AM
07/25/12 10:18 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A Detroit Locker can be annoying to drive on the street because of the excessive internal lash.
Re: Detroit Truetrac Vs. Locker Limitation Q's [Re: DoctorDiff] #1273425
07/25/12 08:51 PM
07/25/12 08:51 PM
As I've been reading about the Truetrac, I like the design and principles of it...just want to make sure I'm not going to grenade the thing dumping the clutch, etc...
Re: Detroit Truetrac Vs. Locker Limitation Q's [Re: 4speeds4me] #1273426
07/26/12 12:55 AM
07/26/12 12:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use a Detroit Locker in my 63 and it has been in the car about 5 years. I myself like it as in normal driving I dont even notice it. But it will make some noise sometimes when locking back up after making a turn or getting into it before the car is straight and the diff has locked both wheels. I have run 10.70 with it and no problems. Here is a vid I found about it. I dont know much about the True Track as I have never used it but since I use a Detroit Locker I thought I would tell you about it. Ron
http://www.youtube.com/watch?v=FYBOoljH-qE&feature=related
Re: Detroit Truetrac Vs. Locker Limitation Q's [Re: 383man] #1273427
07/26/12 01:44 AM
07/26/12 01:44 AM
Thanks Ron. Gives me more info, for sure. I'm not sold on either unit, but in looking for a Mopar SG unit (preferably clutch type) I'm finding that I might be just as far ahead to buy a new unit from Detroit...especially when I factor the possibility of having to rebuild a used unit shortly after installing it.
