Best place to mount relay for fuel pump? #1272833
07/23/12 06:48 PM
07/23/12 06:48 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Should it be back by the fuel pump or should it be closer to the alt/battery? Or does it make any difference?
Re: Best place to mount relay for fuel pump? [Re: frank] #1272834
07/23/12 06:51 PM
07/23/12 06:51 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I would put it closer to the battery, so when turned off, you have less of the line with voltage in it through the car. (with chance of damage/shorting)
Re: Best place to mount relay for fuel pump? [Re: OzHemi] #1272835
07/23/12 07:01 PM
07/23/12 07:01 PM
Andrewh Offline
Andrewh  Offline
I run a 50 amp fused lead to the back behind the back seat, then run relay's back there. cleaner and hides them inside.
Re: Best place to mount relay for fuel pump? [Re: Andrewh] #1272836
07/23/12 07:29 PM
07/23/12 07:29 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i put a 30amp fuse by the battry and the relays in the trunk. then run the power lines thru the gas gage hole in the floor.
perception is 90% of reality
Re: Best place to mount relay for fuel pump? [Re: Mr T2U] #1272837
07/23/12 08:29 PM
07/23/12 08:29 PM
IN
ahy Offline
ahy  Offline
IN
Whatever is convenient and keeps the loaded wire run as short as possible. I have the battery in the trunk so I mounted the relay there also. Its a short run from there to the fuel pump. I still have to run the relay control wires from front to back but they are low load.
Re: Best place to mount relay for fuel pump? [Re: frank] #1272838
07/23/12 11:43 PM
07/23/12 11:43 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
Put mine behind the passenger kick panel.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
