Indy head users...Ever see this? #1272807
07/23/12 06:46 PM
07/23/12 06:46 PM
PA
moparacer Offline OP
PA
I broke a valve spring on my engine and when it broke, it spun around and chewed up the spring pocket that was machined into the head. I had been having trouble with metal in the oil ever since I put these -1s on the engine, and as a matter of fact, it blew up the first day out with the new heads on it...
Well, come to find out after I pulled it apart last night that the metal around the spring pockets is so thin in spots, the springs can break chunks of it off and get into the oil.
Look at this pic of the spring pocket that broke.
See where it had been breaking off prior to the spring breaking? And look at the spring right beside it. See where its been breaking off and getting into the oil? There is a piece about ready to go....
Just thought I would post this and save someone a years worth of headache and broken parts like I have had....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Indy head users...Ever see this? [Re: moparacer] #1272808
07/23/12 07:10 PM
07/23/12 07:10 PM
Cab_Burge Online work
Cab_Burge  Online Work
I bought a used set of 440-1 recently that had the same deal. the springs eating up the heads around the spring pockets I went ahead and machined them flat and bought a set of hardened spring seats that center on the valve guides for my size springs
Re: Indy head users...Ever see this? [Re: moparacer] #1272809
07/23/12 07:10 PM
07/23/12 07:10 PM
Delray beach, Florida
P
Performance Only Offline
P
machine the heads for a proper spring cup and that'll end your problems.
machine shop owner and engine builder
Re: Indy head users...Ever see this? [Re: Performance Only] #1272810
07/23/12 07:32 PM
07/23/12 07:32 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
cups locate the spring better then straight shims.
Re: Indy head users...Ever see this? [Re: rickraw] #1272811
07/23/12 07:52 PM
07/23/12 07:52 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The price difference between hardened valve spring shims and cheap valve spring shims isn't that big of a deal. BUT people want to save a buck so they use the cheap ones.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Indy head users...Ever see this? [Re: pittsburghracer] #1272812
07/23/12 08:04 PM
07/23/12 08:04 PM
PA.
"Little"John
"Little"John
PA.
Pretty sure it was hemi Fred that posted the link showing how much a valve spring rotates in the pocket at different rpm's. I couldn't find the link but it is a good one to watch.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Indy head users...Ever see this? [Re: moparacer] #1272813
07/23/12 09:33 PM
07/23/12 09:33 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Indy head users...Ever see this? [Re: Dodgem] #1272814
07/23/12 09:39 PM
07/23/12 09:39 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
just need machine new pockets and get good locater's ,the std indy ones are crap
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Indy head users...Ever see this? [Re: Ian] #1272815
07/23/12 10:03 PM
07/23/12 10:03 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
I put spring cups on day 1...have to have those
No issues...
Dan
Re: Indy head users...Ever see this? [Re: Performance Only] #1272816
07/23/12 10:13 PM
07/23/12 10:13 PM
PA
PA
Whats the proper spring cups? Its a 1.55 OD spring supplied by Bullet. #VS8100
As you can see they have the locators for the inner springs on them already.
Re: Indy head users...Ever see this? [Re: pittsburghracer] #1272817
07/23/12 10:19 PM
07/23/12 10:19 PM
PA
PA
Believe me I don't try to save a buck for anything and I didn't set these up like this...
Sorry....
Re: Indy head users...Ever see this? [Re: moparacer] #1272818
07/23/12 10:25 PM
07/23/12 10:25 PM
pa
catman408 Offline
catman408  Offline
pa
you know u r a chepskake. put a smallblock in and your problems gone.
1989 lebaron 408 B1BA 5.969 1/8@ 116.16 9.393 1/4 @ 148.83 New motor 426 w8 5.683 @122.49 1/8 8.88 @153.49 1/4
Re: Indy head users...Ever see this? [Re: catman408] #1272819
07/23/12 10:29 PM
07/23/12 10:29 PM
PA
PA
The next small block will be a Chevy Felix.
I could have bought 4 or 5 for what I have went through trying to be a Mopar purist.
And I would bet a Brodix or a Dart head would have the spring seats cast properly to boot.
Re: Indy head users...Ever see this? [Re: moparacer] #1272820
07/23/12 10:32 PM
07/23/12 10:32 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
your locator may be the wrong size for your spring
COMP VALVE SPRING ID LOCATORS 1.550" O.D. Spring Inside Dia .715" .060" Thick
Re: Indy head users...Ever see this? [Re: Ian] #1272821
07/23/12 10:46 PM
07/23/12 10:46 PM
PA
PA
Mine are .060 thick .730 ID and correct for the spring.
Re: Indy head users...Ever see this? [Re: moparacer] #1272822
07/23/12 11:50 PM
07/23/12 11:50 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
try these COMP CAMS VALVE SPRING LOCATOR SEAT CUPS 1.780" O.D. .640" I.D. .060" Thick
Re: Indy head users...Ever see this? [Re: Performance Only] #1272823
07/23/12 11:57 PM
07/23/12 11:57 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Correct!
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Indy head users...Ever see this? [Re: bigtimeauto] #1272824
07/24/12 01:05 AM
07/24/12 01:05 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
when i foolishly ordered my heads thru ICH i asked them to be machined for 1.625 spring cups, "you don't need them" was their answer," you can do everything with a 1.550 spring". ok i'll go with that so i asked them to be machined for 1.550 cups, "you don't need them, spring locators are much better", well they were wrong & i experianced exactly what you posted. first time the heads came off i had them machined for cups & lowered the cup seat position 0.040 so i could go for 2" installed if i needed. those spring locator shims were shyte.
Re: Indy head users...Ever see this? [Re: rebel] #1272825
07/24/12 01:30 AM
07/24/12 01:30 AM
PA
PA
If they cast about 1/8 inch more material around the spring seats it wouldn't be a problem with 1.550 springs. I would imagine if you machined them for 1.625 springs it would also take care of it because it would clean off those thin spots that are just about guaranteed to chip and flake off due to the spring harmonics.
Re: Indy head users...Ever see this? [Re: moparacer] #1272826
07/24/12 11:05 AM
07/24/12 11:05 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
That can happen on most any head.Use hardened shims or as mentioned spring cups.Cups can be purchased for most spring diameters.
