62 & 62 Plymouth B-body Wiring Question #1271991
07/22/12 03:29 PM
07/22/12 03:29 PM
dart1962_440 Offline OP
Are the under dash harnesses the same for 62 & 63 Plymouth B-body or at least interchangeable? Any known differences?
Re: 62 & 62 Plymouth B-body Wiring Question [Re: dart1962_440] #1271992
07/22/12 06:37 PM
07/22/12 06:37 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I don't know, but I will look at my aftermarket color coded full car wiring schematic tonight and see what years it mentions,, my car is a 62 b dodge.
Re: 62 & 62 Plymouth B-body Wiring Question [Re: jcc] #1271993
07/22/12 07:53 PM
07/22/12 07:53 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Gauge cluster is different, but other than that everything is in the same place and appears very similar both years.
Re: 62 & 62 Plymouth B-body Wiring Question [Re: topside] #1271994
07/22/12 10:16 PM
07/22/12 10:16 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I used a '63 dash harness in one of my 62's. The difference in gauge clusters is not an issue. The plug and wiring are the same. Compare the bulkhead connectors. I think I may have had to reposition one wire. It's been a long time so I'm not sure. What I can say for sure is there were no major differences.
Re: 62 & 62 Plymouth B-body Wiring Question [Re: TooMany62s] #1271995
07/22/12 10:19 PM
07/22/12 10:19 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You can be sure Rick,you don't have to change anything.
Re: 62 & 62 Plymouth B-body Wiring Question [Re: 62maxwgn] #1271996
07/22/12 10:34 PM
07/22/12 10:34 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
FWIW, my classic wiring chart says 62 dodge dart (B), which likely to help sell more charts
