M/T ET Street Radials? #1271901
07/22/12 01:21 PM
07/22/12 01:21 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
I've got a dumb question. I've got a new set of P315/60R-15's what air pressure is everyone running on the street with these things? Dave
Re: M/T ET Street Radials? [Re: quickd100] #1271902
07/22/12 01:35 PM
07/22/12 01:35 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
I run about 25 psi on the street, then lower them down to 15-ish at the track
Re: M/T ET Street Radials? [Re: quickd100] #1271903
07/22/12 01:37 PM
07/22/12 01:37 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
35 on the street, 19 at the track.
Re: M/T ET Street Radials? [Re: dustergirl340] #1271904
07/22/12 01:38 PM
07/22/12 01:38 PM
nielsville, minn.
Q
Q
nielsville, minn.
Thankyou, gives me a place to start. Dave
Re: M/T ET Street Radials? [Re: quickd100] #1271905
07/22/12 02:56 PM
07/22/12 02:56 PM
Renton Washington
Triple Threat Offline
Renton Washington
18 everywhere
I like a smooth ride LOL
We run my dads 315/60's at 14-16# when racing.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: M/T ET Street Radials? [Re: Triple Threat] #1271906
07/22/12 05:05 PM
07/22/12 05:05 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
25 street and track...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: M/T ET Street Radials? [Re: Von] #1271907
07/22/12 06:40 PM
07/22/12 06:40 PM
Alliance, Ohio
V
Valiant_Showoff Offline
V
Alliance, Ohio
28 on the street. 17.5 at the track.
255/60's on 7" rims.
Re: M/T ET Street Radials? [Re: quickd100] #1271908
07/22/12 07:15 PM
07/22/12 07:15 PM
michigan woods
imfixinmopars426 Offline
michigan woods
is it really going to matter? from the sounds of the monster turning them,they dont have a chance..lol
Re: M/T ET Street Radials? [Re: imfixinmopars426] #1271909
07/22/12 09:53 PM
07/22/12 09:53 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I run 15 but think I'm gonna try a little higher next time.
Mopar Performance
Re: M/T ET Street Radials? [Re: moparniac] #1271910
07/22/12 10:28 PM
07/22/12 10:28 PM
nielsville, minn.
Q
Q
nielsville, minn.
Well I tryed 26#'s, stopped out on my semi-private test track. I dropped it in low, nailed it, shifted to 2nd and had to get out of it or I'd have waded it up in the ditch. I'll try 18lbs. next go around, the tires still seem like they're too hard yet. It probably won't make much difference, this truck motor just makes a pile of tire shreading torque. Dave
Re: M/T ET Street Radials? [Re: quickd100] #1271911
07/23/12 02:43 AM
07/23/12 02:43 AM
Cab_Burge Online work
Cab_Burge  Online Work
On a bad track the bias plys M/T ET Streets work better than the raidals do ( I use the same aize on my Duster, not as much power as yours )On a good trak the radials are faster by up to or more than 1/10 second in the 1/4 mile Put some big tires on it Dave
Re: M/T ET Street Radials? [Re: Cab_Burge] #1271912
07/23/12 06:58 AM
07/23/12 06:58 AM
nielsville, minn.
Q
Q
nielsville, minn.
Hey Cab!, These are my street tires only. I've got a set of M/T 14-32.5 radial drag slicks for the track.
At 26 lbs. of air the ride on the ET Streets is very harsh. I'll keep dropping the air pressure and see what happens. Dave
Re: M/T ET Street Radials? [Re: quickd100] #1271913
07/23/12 10:33 AM
07/23/12 10:33 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Dave what size rims are you running with the ET Streets? That brand/size is what I am looking at for the Junkyard truck.
Re: M/T ET Street Radials? [Re: Hemi_Ram] #1271914
07/23/12 12:10 PM
07/23/12 12:10 PM
Ma
Voluster Offline
Voluster  Offline
Ma
I run 18.5 everywhere
street / track
Re: M/T ET Street Radials? [Re: Jeepmon] #1271915
07/23/12 12:20 PM
07/23/12 12:20 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Radials at 15?? they don't "cup" I was told not to go under 18 w/ the radials. I even tried 16 once and they didn't hook at all. I've had both ethe MT radials and the Hoosiers ran both at 30 on the street and 18-19 at the track.
Coming soon!!!!
Re: M/T ET Street Radials? [Re: quickd100] #1271916
07/23/12 12:43 PM
07/23/12 12:43 PM
Alliance, Ohio
V
V
Alliance, Ohio
My ET Radials never hook on the street. And they don't hook at the track without a healthy burnout first. Many folks indicate that very little burnout is needed, but I have found the burnout to be critical to their hook.
Fry them first and then try your launch test. You should see a noticeable difference.
Re: M/T ET Street Radials? [Re: Valiant_Showoff] #1271917
07/23/12 02:30 PM
07/23/12 02:30 PM
nielsville, minn.
Q
Q
nielsville, minn.
Larry; I'm running them on 10" rims. I e-mailed M/T this morning, they shot me back an e-mail. Their recs are 32psi on the street for this size tire.Dave
Re: M/T ET Street Radials? [Re: quickd100] #1271918
07/23/12 02:55 PM
07/23/12 02:55 PM
I forgot to mention mine have worked well on good tracks at 22 to 18 lbs of pressure on MY GAUGE Once they( the radails) start to spn they will not recover like the bias plys do I have to let off to let them grab and then try again, I do let off and shift it in first gear, that will work most of the time I have had them break loose in high gear on the street when I've got a wild a-- urge to floor it over 45 MPH, my converter flashes to 5500 or so
Re: M/T ET Street Radials? [Re: quickd100] #1271919
07/23/12 08:22 PM
07/23/12 08:22 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If you keep changing the tire pressure from street to track, you are changing how the tire loads from outside edges to the middle. I pick a pressure after some track testing and leave it.
Re: M/T ET Street Radials? [Re: Valiant_Showoff] #1271920
07/23/12 08:47 PM
07/23/12 08:47 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
So how many passes do you get out of a set of tires when you fry them each pass? I am curious how well/long they last for street and track driving when ran that hard each burnout.
thanks
Old Geezer Racing
