Re: j heads
[Re: bill8121]
#1271896
07/23/12 12:38 PM
07/23/12 12:38 PM
Posts: 1,708 S. Il. U.S.A.
5spdcuda
S. Il. U.S.A.
I think you're being unrealistic in thinking you can get a set of 40+ year old heads to do what you want for only $1,000.00. To start with you will need hardened seats and almost certainly new guides. Add in milling, possibly both block and intake side and you already have real money involved and all you've done to this point is get them back to new condition. If you don't mind the weight get the Engine Quest/RHS heads. Good valve job and bowl/port work and they will make good power. Personally I don't like weight, especially up high on the engine. I do like easy repairability. So for me it's aluminum. If you already have some good rockers I would get a set of bare Eddys and put in a set of PBM valves [ light, good flow, and reasonably priced ]. Minor bowl/port work and you're good to go. If you need to buy rockers, consider the Indybrocks. Again get them bare. Indy's valves are durable enough, but HEAVY and not as good a flow as PBMs. Indy's come with a 2.05 intake, slightly better intake port/flow and the rockers [ stock big block dimensions ] will work fine with reasonable spring pressures. I've got 50,000 miles on mine. They also have 3/8 hold down studs vs. the standard 5/16 bolts. Cheap speed is an oxymoron, or at least cheap, DURABLE speed is.
Re: j heads
[Re: 5spdcuda]
#1271897
07/23/12 08:24 PM
07/23/12 08:24 PM
Posts: 6,148 Melbourne , Australia
LA360
The $$$ you're talking about spending on your heads aren't going to get the results you're talking about. Look around for a used pair of W2 heads or something similar.
Alan Jones
