What causes stinky idle with performance cam? #1271730
07/22/12 01:16 AM
07/22/12 01:16 AM
Khemi, Stygia
Mebsuta Offline OP
Mebsuta  Offline OP
Khemi, Stygia
What is the biggest culprit of stinky idle with a performance cam? You know, where it smells like a big lawn mower and gets all over you if you walk behind it. Is it overlap, late exhaust valve closing, or something else?
I don't care too much but some gurlz won't ride in a stinky car.
68 Roadrunner. 383 4-spd. Beat up.
Re: What causes stinky idle with performance cam? [Re: Mebsuta] #1271731
07/22/12 02:02 AM
07/22/12 02:02 AM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
Overlap causing reversion.
The reversion is basically spent exhaust doesn't fully exit, and a good fresh charge of fuel and exhaust then don't fully enter, and leads to a poor combustion (which also might be occurring from low-dynamic compression due to very low intake velocity from the big cam). Add it all together and there you have it...poor idle...
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: What causes stinky idle with performance cam? [Re: Prince_Valiant] #1271732
07/22/12 04:01 AM
07/22/12 04:01 AM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Supposedly a four hole or split spacer will help cure this from a standpoint of the exhaust interfering with carb signaling, unless you're running a single-plane intake or a dual-plane with the divider cut down.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: What causes stinky idle with performance cam? [Re: Secret Chimp] #1271733
07/22/12 04:08 AM
07/22/12 04:08 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
People get pretty clean idles with 250+ at .050 cams and others can't get a clean idle with a cam with 20-30 degrees less duration and overlap.
Maybe it's got more to do with the tune up than the camshaft. The time it using total method crowd are usually pretty good at providing a stinky idle most of the time, unless they get lucky.
JMO
Re: What causes stinky idle with performance cam? [Re: RobX4406] #1271734
07/22/12 10:56 AM
07/22/12 10:56 AM
IN
ahy Offline
ahy  Offline
IN
Agree its high overlap (long duration + tight lobe seperation) that is the main factor. I suspect a single plane manifold makes it worse also.
Tuning can help clear it up... at least partly. Adequate initial advance plus the leanest AF that will hold a steady idle. Mine likes 20 degrees initial advance and around 14.5 air/fuel. Getting those two dialed in helped both vacuum and "fumes".
Re: What causes stinky idle with performance cam? [Re: ahy] #1271735
07/22/12 11:34 AM
07/22/12 11:34 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Unburnt fuel. Depending on the carb, can be weak vacuum signal leaving AFB/AVS metering rods at full enrichment.
Re: What causes stinky idle with performance cam? [Re: Mebsuta] #1271736
07/22/12 01:04 PM
07/22/12 01:04 PM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
Put some C-12 race fuel in it and when you find a girl that loves the smell..... Marry her.
Summit has some stuff you add to your fuel that will make it smell like cherries or flowers or something like that...... But I would go with the race fuel idea
Re: What causes stinky idle with performance cam? [Re: GreenGlow] #1271737
07/22/12 01:14 PM
07/22/12 01:14 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
'Put some C-12 race fuel in it and when you find a girl that loves the smell..... Marry her.'
There's some righteous advice...
Re: What causes stinky idle with performance cam? [Re: Mebsuta] #1271738
07/22/12 01:23 PM
07/22/12 01:23 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: What causes stinky idle with performance cam? [Re: Mebsuta] #1271739
07/22/12 01:28 PM
07/22/12 01:28 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I love the smell of Torco 110. Heck, even 93 octane is good.
Re: What causes stinky idle with performance cam? [Re: RSNOMO] #1271740
07/22/12 01:45 PM
07/22/12 01:45 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I agree & get a lot of thumbs up from female truck lovers, but until I swap the huge cam in my 383 mag for the Lunati Truck Avenger cam I ordered, I'm in the same boat. Not only fuel smell & wet tail pipes, but my low stall verter, tall tires & gears makes for lousy low end performance & poor fuel economy. Installing a 1" 4 hole spacer on the Weiand dual plane & 600 eddy carb + bumping initial to 20 improved low end manners a little, but still not acceptable for street performance.
Thought of Rhodes lifters to tame the overlap, but heard they're not that predictable. Think a cam swap is your best solution to not only fix the smell issue, but better performance & fuel economy.
Re: What causes stinky idle with performance cam? [Re: Triggerfish] #1271741
07/22/12 03:07 PM
07/22/12 03:07 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
The reversion caused by overlap/big exhaust and big intake is pulsing air both ways thru the carb. It will meter fuel either way! This make idle/low rpm extra rich. Figure out how to lean it down ( and the idle screws are only part of it) and you can clean it up.
A good carb tuner should know how.
Using a good wide band A/F meter is an easier way.
Re: What causes stinky idle with performance cam? [Re: Dodgem] #1271742
07/22/12 06:06 PM
07/22/12 06:06 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Call me old-school, but I just can't get cozy to the idea of my exhaust smelling like Hires...
Or Frosty...
Re: What causes stinky idle with performance cam? [Re: Mebsuta] #1271743
07/23/12 03:23 AM
07/23/12 03:23 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
What are your initial and total timing numbers?
Are you running vacuum advance plumbed to manifold vacuum or straight mechanical advance?
How much vacuum does it have at idle(in gear if an automatic)?
Re: What causes stinky idle with performance cam? [Re: jbc426] #1271744
07/23/12 06:53 AM
07/23/12 06:53 AM
Khemi, Stygia
Mebsuta Offline OP
Mebsuta  Offline OP
Khemi, Stygia
Right now I use the 383 HP cam in a 383 Roadrunner. It has 46 degrees of overlap. Ignition timing is 8 degrees BTDC, by the book. Don't know what the total is. I use ported vacuum advance. Manifold vacuum at idle is 16 inches at 700-750pm. Runs good, just smells like a big Briggs and Stratton. Always has.
Thing is, I might try something with a tighter LSA and close the intake valve earlier. That gives you more overlap and bumpty hot-for-teacher idle, which gurlz like, but if it's going to be more stinky, they don't like that. Gurlz want it all don't they? Luv them anyway.
Re: What causes stinky idle with performance cam? [Re: dustergirl340] #1271745
07/23/12 07:12 AM
07/23/12 07:12 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Yes, but you're already married. So that means the search continues...
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: What causes stinky idle with performance cam? [Re: Mebsuta] #1271746
07/23/12 08:08 AM
07/23/12 08:08 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I would up your initial timing and than adjust your idle. This should clear it up some. You need to get a timing light on there to figure total as well.
Re: What causes stinky idle with performance cam? [Re: RobX4406] #1271747
07/23/12 08:19 AM
07/23/12 08:19 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
JMO
Put a good tune in her and she won't stink.
Re: What causes stinky idle with performance cam? [Re: ahy] #1271748
07/23/12 08:27 AM
07/23/12 08:27 AM
Cincinnati, Ohio
Cincinnati, Ohio
I use a single plane manifold and my car don't stink at idle. I run 22 degrees intial, I don't know why guys are afriad to run plenty of intial timing.
Re: What causes stinky idle with performance cam? [Re: Challenger 1] #1271749
07/23/12 09:32 AM
07/23/12 09:32 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
JMO
mine was so bad i couldnt even sit at a lite, it would gag people for a country block.i couldnt even tune the car unless i had it facin down wind on a breezy day and i aint jokin.timming and carb fixed it.im runnin a fairly radical street cam.
