hot start problem any ideas?? #1271683
07/21/12 10:21 PM
07/21/12 10:21 PM
Endicott, NY
bnichols Offline OP
bnichols  Offline OP
Endicott, NY
it is on my 78 road runner stock 318 2bbl lean burn removed previous owner installed pertronix, when it is hot like driving to a cruise in tonight shut it down an hour or so later go to start fires up but will stall out then cranks over and over have to hold pedal to the floor to start it and can tell it is flooded smell raw gas bad any ideas where to go with it???
Re: hot start problem any ideas?? [Re: bnichols] #1271684
07/21/12 11:20 PM
07/21/12 11:20 PM
Could be heat vaporizing gas in the bowl into the intake especially if running E10.
Re: hot start problem any ideas?? [Re: bnichols] #1271685
07/21/12 11:43 PM
07/21/12 11:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sounds like carb problem to me...a hour later the car would have cooled off?
Sounds like gas is dripping into the motor while it's sitting, stuck needle and seat??
Re: hot start problem any ideas?? [Re: Challenger 1] #1271686
07/22/12 12:00 AM
07/22/12 12:00 AM
Endicott, NY
bnichols Offline OP
bnichols  Offline OP
Endicott, NY
should i look into putting a new needle and seat in possibly??
Re: hot start problem any ideas?? [Re: bnichols] #1271687
07/22/12 12:17 AM
07/22/12 12:17 AM
IN
ahy Offline
ahy  Offline
IN
Sounds like the "hot soak" is boiling the gas out of the carb and into the manifold. I'd start with a thick (1/2"+) insulating carb gasket.
