can a 5 point harness be run on a 3/4 point type seat?
#1271564
07/21/12 04:34 PM
07/21/12 04:34 PM
Posts: 138 Los Angeles, CA
71_dramaqueen
Los Angeles, CA
Thinking of getting some procar sportsman seats or the summit sport seats. Can these be run with a 5 point harness with the crotch belt over the front or do i need a seat with dedicated holes for the side and crotch straps for NHRA?
Anyone with these seats feel free to chime in with input and such.
1971 challenger. 6.2L Hellcat, T56 Magnum
Re: can a 5 point harness be run on a 3/4 point type seat?
[Re: jcc]
#1271571
07/23/12 12:08 AM
07/23/12 12:08 AM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Ain't no way I'm gonna run with a crotch strap thats not tight and give my boys a running start at it. I actually remember seeing a race at Bowling Green, Ky years ago (UDRA, I think?), where the driver always did his burn out with the belts on, but loose, so he could twist around to see to back up, then tightened the belts before staging. During the burn out the throttle got hung and he got crossed up and hit the big diamond shaped concrete thing that the tree sits on and seperates the two lanes. They had to take him out of the car on a stretcher. The car was from up north somewhere, maybe called the "Humping Padre" ?, I'm not sure, been a long time. I do remember that Jeff Wick was there with the "Matchmaker" Daytona. Bottom line, if you're gonna go to the trouble to put them in, install and use them correctly.
Brian Dunnigan
[Re: '72CudaRacer]
#1271572
07/23/12 02:39 AM
07/23/12 02:39 AM
71_dramaqueen
Los Angeles, CA
You guys are completely right about the safety aspect of putting the anti sub belt around the front. I started thinking about it more and the harness in the car I have been doing SCCA in, and did a little more research. My immediate thoughts always seem to be the laziest and cheapest. I want a sliding and tilting seat thats easy to get in and out for a 95% street car. Wanting your cake and eat it too, most always a compromise for both.
I know Cobreau will pit a "fifth slot" in there non fixed back seats for a bit more $. I might try doing this on these cheap suckers.
I suppose bolting in a 5 point with this type seat and then swapping in a bare bones kirkley for track day would work fine.
