572 hemi fuel system #1271395
07/21/12 01:01 AM
07/21/12 01:01 AM
Davenport, Ia. United States
Jim P Offline OP
Jim P  Offline OP
I am putting together a 572 multi-carb Hemi . I have ran small blocks my entire life and want to start out right. How big and how many fuel lines do I need and how much fuel does it need to put out to run high to mid eight seconds. What kind of fuel pumps and how big do they need to be. I here so many different answers. It has 2 760 holley carbs and is putting out 860 hp. It has 13.0 comp and aluminum heads.
thanks in advance
Re: 572 hemi fuel system [Re: Jim P] #1271396
07/21/12 01:51 AM
07/21/12 01:51 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I use part numbers that are pretty spefic for twins on a tunnel ram. 1050 or 1150's -12AN line from tank to a BG400 pump and pushes thru-10 AN line runs under the intake manifold from pump into a 4 port regulator that exits into four -6 AN hoses.
home of the
Sox and Martin Hemi Duster
Re: 572 hemi fuel system [Re: HEMIFRED] #1271397
07/21/12 12:40 PM
07/21/12 12:40 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
i use a magna fuel prostar 500 #10 to the reg then 2 #8 to the carbs.
Re: 572 hemi fuel system [Re: Jim P] #1271398
07/25/12 12:03 PM
07/25/12 12:03 PM
an8sec70cuda Offline
I use the Aeromotive A1000 pump, -10 feed, -8 return, stock tank w/ a sump.
CHIP
'06 GMC 2500HD LBZ Duramax
