dana 60 gear ratio change #1271297
07/20/12 08:58 PM
07/20/12 08:58 PM
Connecticut,usa
K
kjg Offline OP
kjg  Offline OP
K
Connecticut,usa
Looking at a car with 4:10's How hard is it to change the ratio to something higher And what would you recommend for a cruiser
Re: dana 60 gear ratio change [Re: kjg] #1271298
07/20/12 10:51 PM
07/20/12 10:51 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
The tallest gear you could get is a 3.54 and that would work out good. Now changing the gears in a dana is something I would not attempt if I had no experience with one. Let someone with experience do it.
Re: dana 60 gear ratio change [Re: WheelsUp73] #1271299
07/22/12 12:16 AM
07/22/12 12:16 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
3.54 is the tallest common gear. Someone said Ford had a 3.21 a few years back.
this is not a diY job, special tools to spread the case, press the bearing and measure gear clearance.
With some tall tires it will work OK.
Re: dana 60 gear ratio change [Re: sthemi] #1271300
07/22/12 07:32 AM
07/22/12 07:32 AM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
Ford had 3.33 in a Dana 60
