Page 11 of 12 1 2 9 10 11 12
Re: Keisler SS 700 [Re: edco440] #1271229
11/04/13 02:17 AM
11/04/13 02:17 AM
indy
E
edco440 Offline
edco440  Offline
E
indy
#3
Re: Keisler SS 700 [Re: edco440] #1271230
11/04/13 07:43 AM
11/04/13 07:43 AM
Oceanside CA
relax383 Offline
relax383  Offline
Oceanside CA
I am interested to see how well its fits for you. keep us posted.
interesting crossmember is that e-body only I wonder?
Re: Keisler SS 700 [Re: edco440] #1271231
11/04/13 11:40 AM
11/04/13 11:40 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I mocked up the trans to the X-member to ensure the shifter would protrude thru the new tunnel hump opening which is pre-cut and drilled for the trim ring/boot.
From experience, I always suggest you cut the basic shape for a 4 spd hump into the floor, mock up just the bellhousing,trans, and crossmember, obtain the approx. driveline angle your looking for, then trim any additional floor needed for clearance, then tack in the hump for a desired fit/clearance, then remove the transmission mock up, and finish off the floor mods....you'll thank yourself later for doing it that way.
Mike
Re: Keisler SS 700 [Re: DAYCLONA] #1271232
11/04/13 05:46 PM
11/04/13 05:46 PM
indy
E
edco440 Offline
edco440  Offline
E
indy
I always read your posts and you have helped me in the past. Thanks Mike,,I'll heed your advice!
Re: Keisler SS 700 [Re: edco440] #1271233
11/04/13 08:02 PM
11/04/13 08:02 PM
va.
belvedere Offline
belvedere  Offline
va.
looks good.was courios what all came with your kit,how long did it take to get,and finally what did it cost.cant wait to see more pics of your progress. thanks for your time.
Re: Keisler SS 700 [Re: belvedere] #1271234
11/04/13 09:38 PM
11/04/13 09:38 PM
indy
E
edco440 Offline
edco440  Offline
E
indy
Thanks Belvedere! I ordered the Kit in March 2013,,,I finally received it in Oct.2013. I think the current E-Body orders will be filled quickly but ask Keisler to make sure!! When I ordered mine the E-Body units were still being developed and corrections implemented due to problems with the B-Body units. The Kit consisted of the SS 700 Trans, The Keisler Alloy Bellhousing, 9.5" RAM Twin disc Clutch with aluminum Flywheel. Clutch/Brake pedal assembly, Pistol Grip Shifter, Hydraulic Clutch actuator assembly,(Slave cylinder), Crossmember, 1350 Driveshaft. Cost was $6,353,(Total includes shipping and Taxes). I paid for it in full in March, although Keisler asked for 1/2 payment, I went ahead and paid for it all. You will need a Machinist dial indicator, not the plunger type,,but a dial back type as used on Milling Machines for set-up,,0-15-0. Here is a pic. The indicator probe should be perpendicular to the face of the bellhousing's flange, then zeroed. The instructions state this clearly. This probe will cost you approx. 50-100 depending on the brand you choose. I like Starrett or Mitutoyo but they are pricey. You will also need a tool to remove the block dowel pins, I made my own,,but you can get one for 50-100 also. An old set of stamped steel,(Cast is difficult to weld) Vise grips, welder, and a slide hammer is what I used. An angle gauge is required to determine driveline angle, a cheap plastic protractor can be used. Hope this helps,,thanks again,,Eddie
Re: Keisler SS 700 [Re: edco440] #1271235
11/05/13 09:48 PM
11/05/13 09:48 PM
va.
belvedere Offline
belvedere  Offline
va.
looks good looking forward to more posts of your progress.thanks for your time. belvedere.
Re: Keisler SS 700 [Re: belvedere] #1271236
11/24/13 03:48 AM
11/24/13 03:48 AM
indy
E
edco440 Offline
edco440  Offline
E
indy
So Far, so good.Dialed in the Bellhousing, I needed a .014 offset Dowel Pin to get < or = to .005(TIR) .010 Indicated ,, after that was accomplished, I mounted the RAM Twin Disc clutch, then the LGT. The SDC Serpentine Belt drive from Jerry and the TTI Headers should be here in a few weeks, then the body drop! Happy Thanksgiving&Merry Christmas
Re: Keisler SS 700 [Re: edco440] #1271237
11/24/13 03:51 AM
11/24/13 03:51 AM
indy
E
edco440 Offline
edco440  Offline
E
indy
pic 2
Re: Keisler SS 700 [Re: edco440] #1271238
12/02/13 07:41 PM
12/02/13 07:41 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Looks good so far. Keep us posted!
Re: Keisler SS 700 [Re: 2fast4yourBrain] #1271239
12/21/13 07:02 PM
12/21/13 07:02 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Re: Keisler SS 700 [Re: 2fast4yourBrain] #1271240
01/02/14 05:42 AM
01/02/14 05:42 AM
indy
E
edco440 Offline
edco440  Offline
E
indy
Brake & Clutch Pedal installed.(Thanks for the schematic Mike,,Dayclona), Wilwood Clutch Master.
Re: Keisler SS 700 [Re: edco440] #1271241
01/02/14 05:48 AM
01/02/14 05:48 AM
indy
E
edco440 Offline
edco440  Offline
E
indy
#2,,waiting on my TTI headers and the rest of my SD parts from Jerry. He's making a hose kit and his own custom pulleys,,I have the brackets and they are sweet!(SD Concepts B/RB Dodge Magnum V-8 serpentine belt drive kit) Getting very close to the body drop.
Re: Keisler SS 700 [Re: edco440] #1271242
01/25/14 10:41 AM
01/25/14 10:41 AM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
Please this on-topic. That means, keep it tech related. There's thread in the General forum if you want to discuss the business/bankruptcy side of things. If this thread continues to veer off-topic, it'll get locked, which won't help anyone. Thank you.
https://board.moparts.org/ubbthreads/show...e=0#Post8010497
Earning every penny of that moderator paycheck.
DBAP
Re: Keisler SS 700 [Re: not_a_charger] #1271243
01/27/14 03:59 PM
01/27/14 03:59 PM
indy
E
edco440 Offline
edco440  Offline
E
indy
I see some of my posts were deleted. I will refrain from posting my results on this site. I'll be next door on Cuda Challenger or the Challenger Message Board. Edco440 OUT
Re: Keisler SS 700 [Re: edco440] #1271244
04/19/14 05:26 AM
04/19/14 05:26 AM
Oceanside CA
relax383 Offline
relax383  Offline
Oceanside CA
How did your e-body install turn out?
Re: Keisler SS 700 [Re: relax383] #1271245
06/12/14 12:58 PM
06/12/14 12:58 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
bump for more info.
Re: Keisler SS 700 [Re: edco440] #1271246
06/12/14 01:56 PM
06/12/14 01:56 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Be sure to check that the face of the rear of the bellhousing is parallel with the crank flange, assuming there's no run-out there. I had to shim between my scattershield and block to get them parallel there. I'm guessing the back of the block was square, but the scattershield had some run-out which took it a few thousandths out of parallel. I used shims next to and on either side to bolts behind the main bolt that hold on the scatter shield between the block saver plate and the block. Many folks never check this, but it is important!
Also, how much power is that motor going to put out at what RPM with no scatter shield? Yikes!! Or, is that bellhousing SFI rated as explosion proof. Just a concern after seeing pictures of what an exploding flywheel and clutch can do to a car and a person.
Re: Keisler SS 700 [Re: jbc426] #1271247
06/12/14 07:53 PM
06/12/14 07:53 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Looks good. My SS(LGT)-700 is working good now, Hammered pretty good on it last week at the track, but my reverse light switch quit working...
Re: Keisler SS 700 [Re: 451Mopar] #1271248
06/14/14 04:06 PM
06/14/14 04:06 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
You have a thread on your whole experience w/this trans?
Like x-member hacking, etc.?
