Re: Keisler SS 700
[Re: Convertible Bee]
#1271130
02/17/13 04:08 PM
02/17/13 04:08 PM
Posts: 65 Solon, Oh
Convertible Bee
Solon, Oh
Well was bored, did some fitting, had an oh $#!@ moment, my fault...
Trans is up where I think it should be, had to trim the shifter hole a bit more...
What do you guys think, close enough?
Made a template to use for clearance, all trimmed well on the ss700, no structural compromises, though here's my oh crap, didn't look at where the o ring for the speedo was and ground where it seals off... my fault!! I'll get around that, no big...
So as I see it, the speedo cable input needs to be on a steeper angle to clear,(it would be an easy fix for keisler when manufacturing), the edges trimmed for the b body cross member,(easy fix) and the Keisler cross member needs to be corrected for the height change (also an easy fix for Keisler),last thing, shifter perch, at least for automatic to manual conversion, needs to be 180 degrees, this would put the adapter in the center of the console boot when in neutral,(easy fix)... I've done your R&D and posted it, correct this transmission's problems before you send any others ss700's that don't fit... this could be a descent transmission and an easy install...
These are my opinions and observations on this install your experience may vary. Tim
Last thought on this today... If you cant't fix it with a hammer, the problems electrical...
Re: Keisler SS 700
[Re: relax383]
#1271133
02/17/13 09:01 PM
02/17/13 09:01 PM
Posts: 65 Solon, Oh
Convertible Bee
Solon, Oh
nicely done Convertible Bee I would also suggest sending Legend these pics and info so they might use it in the future.
To the moparts guys who shared ideas, input, comments and info with me.
Thanks for the positive comments and emails, your why this forum is GREAT!!!
Tim
PS anyone have a console bracket, the center one, mine came out with the auto shifter. Thanks
Re: Keisler SS 700
#1271134
02/17/13 09:49 PM
02/17/13 09:49 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
That was not really that bad to get it in there, let us know how it shifts when you start driving it.
A new iron curtain drawn across the 49th parallel
Re: Keisler SS 700
[Re: 67autocross]
#1271135
02/18/13 02:21 AM
02/18/13 02:21 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Thanks for all the input. I should have my SS700 next month. Going into the '69 Coronet 4-speed car, and I am using the stock clutch linkage / mechanical throw-out bearing, so it may use a different retainer? I ordered pretty much the entire kit except clutch linkage, so it will be coming with Keislers bellhousing, inspection cover, console shifter, clutch, pressure plate, etc. I'll post some pictures when it shows up.
Re: Keisler SS 700
#1271137
02/18/13 11:53 AM
02/18/13 11:53 AM
Posts: 1,822 Colorado
denfireguy
Colorado
The animosity and "shots across the bow" aside, this is a great thread. Thanks Tim for taking us all along for the ride. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: Keisler SS 700
[Re: 451Mopar]
#1271140
02/18/13 08:32 PM
02/18/13 08:32 PM
Posts: 65 Solon, Oh
Convertible Bee
Solon, Oh
Just a note from my communications with Keisler, the bell housing you are getting from them will have the 4.849 pilot and the tremec (ford) bolt pattern... no big...
it's a matched set, so you shouldn't have the issue I did on mounting to a stock mopar bell housing...
keep in mind that if you decide later to use a different housing lakewood offers a mopar bell with a tremec pattern...
As for your clutch, I'm hydraulic and will deal with it as soon as the speedo issue it resolved on my install, please keep us posted how your mechanical clutch works out...
Re: Keisler SS 700
[Re: relax383]
#1271141
02/18/13 09:12 PM
02/18/13 09:12 PM
Posts: 65 Solon, Oh
Convertible Bee
Solon, Oh
I sent Legend a copy of this thread via facebook. I got a response from the front desk saying they were passsing it on to the engineers and desginers hopefully they read it and can fix the little things because really its all just little stuff. But the devil is in the details.
good call, I didn't see an email for them on their website, was wondering how to get it to them...
I agree on this stuff is no big deal, just inconvenient...
Re: Keisler SS 700
[Re: wegner426]
#1271143
02/19/13 01:01 AM
02/19/13 01:01 AM
Posts: 65 Solon, Oh
Convertible Bee
Solon, Oh
Is the correct bellhousing supposed to be included in the price or is that extra?
It would have been $300 extra for me...
Re: Keisler SS 700
#1271145
02/19/13 09:43 PM
02/19/13 09:43 PM
Posts: 65 Solon, Oh
Convertible Bee
Solon, Oh
Spoke with Shafi and David from Keisler today. The outcome of the conversation was satisfactory to me. They are going to work through and assist me with the issues with my trans swap. The highlights are: 1) The issue with the bolt pattern and pilot for the stock Mopar bellhousing is resolved. If you order a trans to fit a Mopar bell it will have the correct bolt pattern and pilot size for a stock Mopar bell. If you order a Keisler bellhousing the trans will fit that bell; remember the Keisler bellhousing has the tremec bolt pattern and pilot. 2) The stock to get the tail higher in the tunnel, will be taken care of too. This was minor but did prevent the trans from lifting completely to the position that I needed. So no problem there now. 3) The speedometer cable location -- we discussed on how the stock B-body cross member frame interfered. They are going to see if the cable mount location can be clocked to allow more clearance to the frame. From my measurements I feel that this is very possible as long that there is wall stock in the casting. About 5 degrees should do it. *Side note -- On their XP Charger the engine appears to sit flat but slightly lower. This is why I believe the cable was placed where it was. I would have missed that too. In reality I am amazed it fit at well as it did with this trans being able to fit as many cars as it does. A few tweaks in the beginning are to be expected. 4) The shifter location, Shafi assured me would be correct when I start the final assembly. Because of his willingness to help out with the other concerns, I believe it will. *Final Thought - With these concerns corrected I feel this will be a very affordable overdrive transmission for our B-bodies. Tim
Re: Keisler SS 700
#1271147
02/20/13 12:31 AM
02/20/13 12:31 AM
Posts: 6,090 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
Glad it's going good. Awaiting a test drive!
