Re: Does It pay to Weld this Block??
[Re: R/T1968R/T]
#1270924
07/20/12 02:29 PM
07/20/12 02:29 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Picked up a 1968 440HP with fresh machine work for $25. It is bored .030 and clean. It has an external crack in the water jacket. I was quoted $300-400 guaranteed and pressure tested. 68HP motors dont grow on trees. Is it worth fixing??
ASSuMEing its not the original engine to a car you currently only that is up to you to decide as it's not ever going to be the original engine no matter how close dates and such are.
[Re: RUNCHARGER]
#1270926
07/20/12 02:44 PM
07/20/12 02:44 PM
Triple Threat
Renton Washington
Depends on what you mean by fresh machine work, if someone sunk $1,000 into the block to have it bored, honed, etc etc and all it needs is the crack fixed, I would give it a shot.
Personally, The fact its a 68 HP block has zero bearing on my decision.
[Re: R/T1968R/T]
#1270929
07/20/12 04:41 PM
07/20/12 04:41 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
Its been freshly bored and honed and square decked.
If you are just welding on the exetior water jacket will you need to re-machine/hone everything straight again?
[Re: 1_WILD_RT]
#1270931
07/20/12 06:27 PM
07/20/12 06:27 PM
Challenger 1
Cincinnati, Ohio
Back when Hemi stuff wasn't around I had a Hemi head repaired. It was great for a few months then it opened up again. So I was out the cost of the repair, the machining and then I had to go find another head and do it all over again anyway. Good money after bad, and you'll always be wondering when it's going to open up again.
Sheldon
And this is why you don't weld it... Lock n Stitch, used in automotive & industry for many years, trouble free won't need to remachine the block... They sell DIY kits for reasonable money...
Yes it's a amazing repair method, invented by a german? guy like 100 years ago?
I watched a old boss do that repair 25 years ago. I was amazed.
[Re: Challenger 1]
#1270932
07/21/12 10:56 AM
07/21/12 10:56 AM
Posts: 10,731 North Dakota
6PakBee
North Dakota
I would be more concerned about there being more cracks than just the one you found. As to repairs, the plugging method is a good, proven, no heat method to repair a crack in something that operates at moderate pressure and temperature.
[Re: R/T1968R/T]
#1270933
07/21/12 11:32 AM
07/21/12 11:32 AM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
my 440 has a external crack front rt side from no antifreeze. jb weld 15 years ago. 9.13sec 148 mph if its a stress crack might be a problem gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: R/T1968R/T]
#1270936
07/21/12 06:32 PM
07/21/12 06:32 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Can you send me a pick of the cracked in the block....what part of the block is cracked....where are you located?
RIP Monte Smith
[Re: slantzilla]
#1270940
07/22/12 03:33 AM
07/22/12 03:33 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
I've drilled & welded lifter valleys & almost every kind of outside water crack that you can imagine for years Lifter valley cracks get a dose of ceramic block sealer The outside gets ground smooth & a epoxy worked in with a solid steel roller Preheating & short welds V the crack good The ones too close to a machine surface I drill tap & loctite valve cover studs & a dose of epoxy I've welded pan rails back in & all Another member here helped me improve my process about 20 years ago with great success (the welding) He does a lot of head & block repair The hoot is the welding is done with a MIG & it works
