There is no local transmission shop either, hence the dilema.
All solved now.
Gave the newer application to the dodge store , as per johnrr. Got the newer seal easy then. They knew the number for that one off the top of thier heads.
I like that the newer seal also had a lip on the metal part so it couldn't be installed wrong, depth wise. Just tap it in, and it's all good.
Started the R and R at 3. Drove it home at 6.
Thanks again Moparts. Awesome, as always
Here is the rig in question
1949 Fargo B1B Front end is 05 crown vic. Rear end is 4 link on a 67 B 8.75 housing.
Motor is 400 B engine. 10:1 with a bit of a cam. Rock on
I've got about 1500 hours in this int he last year. Ready to roll. On our way to the Old Time drag event in Mission BC next week. Should be awesome
