Gas tank ? #1270609
07/19/12 09:59 PM
07/19/12 09:59 PM
The Motor City
Stew4706 Offline OP
Stew4706  Offline OP
The Motor City
Hey Guys, I have a 79 power wagon with 2 tanks. The gas gauge in the original tank has not worked for at least 10 years. It was that way when I bought it and I finally got around to looking at it. Turns out to just be a ground issue. Now for the issue the tank is completely empty and stinks like varnish. It was allegedly run dry by the original owner. Should I just fill her up and assume the muck will dissolve or should I yank it and clean it?
I should mention that it is a poly tank and the truck only has about 56,000 miles. Appreciate your input.
Thanks Moparts.
Re: Gas tank ? [Re: Stew4706] #1270610
07/19/12 10:27 PM
07/19/12 10:27 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Pulling it and cleaning it would be the smart thing. I would probably just dump some gas in and run it. Nobody ever accused me of being smart!
Re: Gas tank ? [Re: DaytonaTurbo] #1270611
07/20/12 10:48 AM
07/20/12 10:48 AM
The Motor City
Stew4706 Offline OP
Stew4706  Offline OP
The Motor City
Honestly that is kind of how I feel. I am waiting for the one horror story that will push me over the fence.
Re: Gas tank ? [Re: Stew4706] #1270612
07/20/12 11:05 AM
07/20/12 11:05 AM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
I would pull it and clean it. Otherwise, gas will start dissolving that varnish and send it right to the carb. It's not worth the risk of mucking everything up.
