Aluminum Hemi Heads - Dual Plug - QUESTION #1270561
07/19/12 08:08 PM
07/19/12 08:08 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I have a set of aluminum Hemi heads with a casting #3614433 with dual plugs. I need a replacment block off bolt for the dual spark plug. Does anyone know where I can get one??? I believe these heads were Direct Connection cyl hds.
Re: Aluminum Hemi Heads - Dual Plug - Bolt Needed [Re: faud88] #1270562
07/19/12 09:29 PM
07/19/12 09:29 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Brad Anderson in California will have them or will be able to tell you where to get them. I'm almost postive they will have them.
Re: Aluminum Hemi Heads - Dual Plug - Bolt Needed [Re: Challenger 1] #1270563
07/19/12 10:15 PM
07/19/12 10:15 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Thanks! I will look them up. Any other suggestions out there??
Re: Aluminum Hemi Heads - Dual Plug - Bolt Needed [Re: faud88] #1270564
07/19/12 10:36 PM
07/19/12 10:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Why not just run a plug in the hole, I know it won't be functional but it will likely be cheaper.
Don't be the exception.
