Horsepwer/torque gain with rear gear change ? #1270295
07/19/12 12:46 AM
07/19/12 12:46 AM
, Kansas popu.512
Mopardude440 Offline OP
, Kansas popu.512
was curious how much gain i could expect changing rear gears to 3.55 or 3.91 i have 3.23 now 69 roadrunner 4-speed 28in tire 440 510 hp/ 540 tq flywheel 310 hp/ 415 tq rear wheel 4400, redline thought would have done better but dyno crew says my rear gear is killing it,
Re: Horsepwer/torque gain with rear gear change ? [Re: Mopardude440] #1270296
07/19/12 01:07 AM
07/19/12 01:07 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I don't think there should be any change.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Horsepwer/torque gain with rear gear change ? [Re: RoadRunner] #1270297
07/19/12 01:20 AM
07/19/12 01:20 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
It cant change H.P. but you will see a performance gain. I would recommend the 3:55
Re: Horsepwer/torque gain with rear gear change ? [Re: west] #1270298
07/19/12 01:35 AM
07/19/12 01:35 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
It will change the horsepower and torque level your system operates in at rpm levels.
Ride eternal, shiny and chrome
Re: Horsepwer/torque gain with rear gear change ? [Re: Mopardude440] #1270299
07/19/12 02:54 AM
07/19/12 02:54 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
3:91...
Re: Horsepwer/torque gain with rear gear change ? [Re: west] #1270300
07/19/12 05:19 AM
07/19/12 05:19 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I agree you will not get more hp gain but the steaper gear set will tune your trans/ engine combo so it will perform better showing more power as a matched set
I[ie} it it a matched set engine with right cam, trans rear
Hope I making censer here
changing from 323 to 355 is so little it will not help mubh at all and just mess up the speedo reading lol
I have done it my self when I broke the 323 and had some 355 laying around and did not notice much if at all other than the speedo being off
the big change was 323 to 391 and I liked that as with my cam and compression it when fine on 1-10 interstates well
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Horsepwer/torque gain with rear gear change ? [Re: 340SIX] #1270301
07/19/12 09:29 AM
07/19/12 09:29 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
a gearset won't change the Hp/Tq that the chassis dyno actually sees? I always heard that it would, as gears "multiply torque"
if it doesn't matter what the gear ratios are, then why do they always do the dyno pull in the 1:1 gear?
**Photobucket sucks**
Re: Horsepwer/torque gain with rear gear change ? [Re: Mopardude440] #1270302
07/19/12 09:35 AM
07/19/12 09:35 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I would change the dyno crew first
Re: Horsepwer/torque gain with rear gear change ? [Re: 70Cuda383] #1270303
07/19/12 10:26 AM
07/19/12 10:26 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Actually, it does and they don't.
Typically, the higher the gear (numerically lower), the lower the parasitic loss. Your 1:1 gear will give the least loss since everything is locked together inside the transmission. No gear friction.
That being said, a qualified dyno operator should put the car in the safest gear. That would be one that won't exceed a tire speed rating, or allow an unintended down/up shift during the pull. In the case of a three speed auto, they often put it in second.
A chassis dyno factors out gear ratio.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Horsepwer/torque gain with rear gear change ? [Re: jcc] #1270304
07/19/12 10:29 AM
07/19/12 10:29 AM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
So...if you made a dyno pull in second gear, wouldn't be the same as pulling it in high gear with 4.68 gears? I always wondered if the final gear made a difference on a wheel dyno. Do they have to input final gear ratio and tire diameter before they start?
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: Horsepwer/torque gain with rear gear change ? [Re: DconD100] #1270305
07/19/12 10:42 AM
07/19/12 10:42 AM
The dyno knows the engine rpm and the tire speed, so the overall gear ratio (factoring in tire size) is a pretty simple mathematical computation.
No one has addressed the OP's real concern which is that he has a 510 horsepower engine which is only putting 310 horsepower to the rear wheels. That does seem like a pretty huge power loss through the drivetrain.
Re: Horsepwer/torque gain with rear gear change ? #1270306
07/19/12 11:02 AM
07/19/12 11:02 AM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
I realize that most of Kansas doesn't have a lot of elevation, but if the flywheel horsepower is a corrected number and the wheel horsepower is observed, that could explain some of the huge loss.
Re: Horsepwer/torque gain with rear gear change ? [Re: DconD100] #1270307
07/19/12 11:56 AM
07/19/12 11:56 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
3.91s will theoretically give more parasitic than would 3.23s, all else being equal. Maybe 5%. Probably less.
What is type/brand of chassis dyno? Mustang dynos give notoriously conservative, but arguably more accurate numbers than a Dynojet.
Are those engine numbers verified on an engine dyno? If so, those chassis numbers are low regardless of dyno type or gear ratio. I would expect to see 400+. You've got some serious parasitic loss in the drivetrain. Bad bearings, brake drag, driveline misalignment, etc. Is AFR being monitored during the pulls and is it good?
-Jim
Re: Horsepwer/torque gain with rear gear change ? [Re: jcc] #1270308
07/19/12 12:34 PM
07/19/12 12:34 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Horsepwer/torque gain with rear gear change ? [Re: Mopardude440] #1270309
07/19/12 12:34 PM
07/19/12 12:34 PM
DPelletier Offline
DPelletier  Offline
...and of course, the correct answer is zero.
Re: Horsepwer/torque gain with rear gear change ? [Re: Mopardude440] #1270310
07/19/12 01:48 PM
07/19/12 01:48 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
how do you change an engines potential by adjusting the rearend ratio ?? You'll change speed/rpm with different ratio in all the gears but the horsepower potential remains the same.
Different coverters(for auto guys/gals) will only enhance or decrease the "potential" EXCHANGE from engine to tranny to rearend.
It's like taking a full 16 oz glass of water and putting it in a 32 ounce glass...You still have 16 oz.
Re: Horsepwer/torque gain with rear gear change ? [Re: terzmo] #1270311
07/19/12 01:54 PM
07/19/12 01:54 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Unless you spill some in the transfer process.
-Jim
Re: Horsepwer/torque gain with rear gear change ? [Re: 471Magnum] #1270312
07/19/12 02:07 PM
07/19/12 02:07 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
Also, the type of air filter, headers, and mufflers on the car compared to the engine dyno could cause some loss...especially if the air cleaner lid was so close to the carb it was choking it.
Re: Horsepwer/torque gain with rear gear change ? [Re: Mopardude440] #1270313
07/19/12 02:37 PM
07/19/12 02:37 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
So they didn't take it past 4400? that would explain the okay torque differential but bad HP differential.
BTW that dyno operator probably failed math class.
Sheldon
Re: Horsepwer/torque gain with rear gear change ? [Re: DconD100] #1270314
07/19/12 02:38 PM
07/19/12 02:38 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
and maybe it's a combo of a happy engine dyno and a stingy chassis dyno. if the engine dyno was reading 20-30 high, and the chassis is 20-30 low, that would also account for the variance.
If you really ARE losing that much Hp through the chassis, then start looking for problems...as mentioned, brakes dragging, driveline mis-aligned, bad bearings, maybe a bad torque converter, etc.
also, make sure nothing in the motor has gone bad from engine dyno to chassis dyno. if you are starting to wipe some lobes and have less lift now, or the the intake/exhaust is too restrictive, etc.
I know that how my engine was tested on the dyno, it'll NEVER see that kind of set-up in the vehicle unless I turned it into an all out race car. on the engine dyno there was no air cleaner whatsoever, no turbulance of intake air because there was no hood, no moving air over the carb, etc. just sitting static in a room. on the engine dyno it had the same headers as in the car, but they were open, with a vacuum system over the collector to take the fumes outside, vs a full exhaust in the car. it also had an electric water pump, with no other accessories, and the fuel pump, ignition, etc. was all driven by a stand-alone power source, so the flywheel hp was a pure, free number with NO loss anywhere.
add in a full exhaust, air cleaner, underhood turbulance, alternator, water pump, PS drag, and it wouldn't surprise me if suddenly my flywheel hp was down by 30, and I haven't even begun to account for parasitic loss through the transmission, U-joints on drive shaft, rear end bearings, inertia of the parts, etc.
