Re: Is this a factory original fuel filter?
[Re: ScottSmith_Harms]
#1270218
07/19/12 09:26 AM
07/19/12 09:26 AM
definitely seems original since it has the keystone clamps however, weren't the rubber lines and filter as well as the steel line installed after the engine assembly was painted? I find it weird that there seems to be engine paint on the lower part of the hose.
#1270219
07/19/12 09:28 AM
07/19/12 09:28 AM
Posts: 1,565 tennessee
pushbutton
tennessee
I would also agree that it's likely the original, looks like someone replaced the upper clamp to the carb (no surprise).
I know this is not about the fuel pump,but I thought the original pumps had a short hard line on the discharge side before the filter. Is that correct or did they come both ways? I see some original paint on the hose.
[Re: pushbutton]
#1270220
07/19/12 09:53 AM
07/19/12 09:53 AM
Posts: 21,452 It's a dry heat
gtx6970
It's a dry heat
440 and hemi used the lower hard lines.
383 cars use as shown, note the angle the lower fitting exits the pump
[Re: wally426ci]
#1270222
07/19/12 01:37 PM
07/19/12 01:37 PM
Posts: 381 Denver CO
bennydodge
Denver CO
I know '73 small blocks had it before the pump. Clearly outlined in the service manual..
73 Challenger 340(416),E-heads, 727, 3.23 SG 2015 Challenger R/T classic B5, wife's car 2010 Ram 3500 Crew Cab SLT dually 4X4 2016 Challenger Hellcat Redline Red A8
[Re: burdar]
#1270224
07/19/12 02:13 PM
07/19/12 02:13 PM
bennydodge
Denver CO
Burdar- Was it that way originally? The lubrication and maintenace section of the 1973 service manual shows a picture (fig 25 of the chapter) with the words "fuel filter 318, 340 and 360 engines" and the filter is shown before the pump inlet.
[Re: gtx6970]
#1270225
07/19/12 02:14 PM
07/19/12 02:14 PM
pushbutton
tennessee
Fine Lines list 2pcs lines from the pump to the carb 68-69 383 with AVS,also for 68-71 440 with AVS.
[Re: burdar]
#1270227
07/19/12 02:29 PM
07/19/12 02:29 PM
bennydodge
Denver CO
I have the U-shaped piece(threaded) as well. The service manual shows the filter between the frame rail line and the barbed inlet. I know the fuel line changed after '72. I wonder why the discrepency?
[Re: burdar]
#1270228
07/19/12 02:32 PM
07/19/12 02:32 PM
pushbutton
tennessee
Yes, it was that way originally. The inlet side of the pump just has a nipple for the fuel hose from the main fuel line. The outlet side of the pump has a threaded connection. There is a short section of fuel line bent in a "U" shape...then the filter...then the line that goes up to the carb.
That's what I always thought,although the one in the pic sure looks factory installed,going by the factory type clamp on the outlet.
[Re: pushbutton]
#1270229
07/19/12 02:43 PM
07/19/12 02:43 PM
bennydodge
Denver CO
Your 383 does look original. I'm certainly no expert on '69 models, though. I know on '73's big blocks still have the filter after the pump, but with a small metal line coming out the pump then the filter.
[Re: bennydodge]
#1270230
07/19/12 04:21 PM
07/19/12 04:21 PM
Challenger 1
Cincinnati, Ohio
Wrong!!
[Re: Challenger 1]
#1270231
07/20/12 12:57 AM
07/20/12 12:57 AM
bennydodge
Denver CO
So the service manual is wrong then? Anybody have any pics of an original unmolested '73 340?
[Re: bennydodge]
#1270232
07/20/12 07:34 AM
07/20/12 07:34 AM
Challenger 1
Cincinnati, Ohio
I just know the fuel pump can't suck through a filter made for after the fuel pump, it don't matter what year, gas is gas.
Very few people understand gas and it characteristics. Got to know it to make big power.
[Re: bennydodge]
#1270233
07/20/12 09:18 AM
07/20/12 09:18 AM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
Ive been searching for some good detailed pics of a 73 340 for months with no luck,
