Re: Transmission Adjustment
[Re: Pacnorthcuda]
#1270173
07/18/12 09:11 PM
07/18/12 09:11 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
You can drop the pan and increase the line pressure (to a point).
I was told that not more than two turns CCW was the limit, or damage may result to reverse if engaged at anything other than a LOW idle.
[Re: Hotlumpy]
#1270176
07/19/12 05:25 PM
07/19/12 05:25 PM
Posts: 26,005 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There are a couple of things that can affect the shift firmness, a loose converter or a tall axle ratio (or both) will make the shift feel less firm.
