Window film
#1270060
07/18/12 04:47 PM
07/18/12 04:47 PM
Posts: 1,487 STL
cdstl
STL
I am thinking about putting window film in my Lumina. Window guy wants $260 for 5 windows which isn't crazy money but I thought about doing it myself. I did the rear windows in my K car once.
Just looking at parts store stuff. Any favorites?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Window film
[Re: cdstl]
#1270063
07/19/12 08:31 PM
07/19/12 08:31 PM
Posts: 1,487 STL
cdstl
STL
Thanks for the replies. I need at least 31" and the NAPA roll comes in 100 foot lengths for $200. The quick look at Auto Zone only had it in 24" lengths.
Probably won't happen.
Re: Window film
[Re: AdamR]
#1270066
07/19/12 10:29 PM
07/19/12 10:29 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I did my own. cost me like $15 in tint for the 2 driver side doors on my truck. watched a few videos on youtube before doing it myself. just went slow and was careful. I think the trick is to use LOTS of soapy water, so that the tint glue won't stick to ANYTHING until you squeege the water out from between the film and glass.
**Photobucket sucks**
Re: Window film
[Re: 70Cuda383]
#1270067
07/19/12 10:33 PM
07/19/12 10:33 PM
70Cuda383
Marysville, O-H-I-O
I went with 35%. not super dark, just barely enough to notice, and even then, it's barely noticable.
I was torn between going with a 20% or darker tint, because I wanted tinted windows, but also did not want them so dark that I got trouble from the cops.
Re: Window film
[Re: 70Cuda383]
#1270068
07/19/12 10:40 PM
07/19/12 10:40 PM
70Cuda383
Marysville, O-H-I-O
Also, another trick, I removed all the weather striping from the door completely, so that the glass would rattle back and forth with lots of room in the "window sill" this prevented any issues with trying to push the tint past tight weather stripping, and made the tint very easy to install, while only adding maybe an extra 10 minutes to the job to remove, and then later, reinstall the weatherstriping and window felts around the glass.
I would also cut the tint to size BEFORE removing the backing and soaping up the glass.
and...even with all those tips...I would pay someone to do the back glass if it has compound curves to it, after watching stuff on youtube about heat shrinking the tint to conform to the contours of the glass, I decided that I was glad that A) the back glass on my truck was already done by the previous owner and B) that it was relatively flat in case I ever wanted to peel and re-tint it.
Re: Window film
[Re: AdamR]
#1270070
07/20/12 10:46 AM
07/20/12 10:46 AM
70Cuda383
Marysville, O-H-I-O
Yea, I only suggested to pull the stripping, because the how-to videos I saw on youtube showed them doing it with the stripping still in place, but using a plastic tool to work the tint down below the stripping. I figured that looked like an acquired skill done by a pro to save time and rush a customer out the door.
