My '76 440 has the 100A alternator wich means it's mounted on the nuclear strength brackets. It also has the stock RV2 compressor. I want to swap in a Sanden-style. I am hoping to find out several things first.
1. Do the RV2 and the Sanden-style use the same mounting brackets?
2. Are the pullies the same so I can use the same belts.
3. Will it align up correctly with my crank pulley and alternator pully or will I have to do something with the brackets and or pullies.
4. If the Sanden-style uses it's own brackets, will there be alignment issues?
Or am I making this more complicated than it really is?
