Page 4 of 12 1 2 3 4 5 6 11 12
Re: vibration update on the cuda [Re: Sledge_57] #126924
09/27/08 10:56 PM
09/27/08 10:56 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
You said:
the first time the tranny was apart was over the winter and after that is when they started, the front drum was wiped out, so now i have another new one in there and still now change
I have a question now. Are you saying the problem started after the trans was put back together with a new front drum?
If so maybe the drum is bad and out of balance
yes and i replaced it with another drum to have the same affect
Post deleted by Defbob [Re: cudadan] #126925
09/27/08 11:59 PM
09/27/08 11:59 PM
Re: vibration update on the cuda #126926
09/28/08 08:52 AM
09/28/08 08:52 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
For what its worth I have the same problem with my 73 Challenger. The vibration is rpm related to driveshaft speed. This is why the speed which it occurs changes with gear ratio. I have changed,balanced,swapped the following. Rear pigs & ratios,axles,drums,wheels & tires,driveshafts,trans & engine mounts. The difference is mine is a 4 speed. I can push the clutch in and it still vibrates. My u-joint angles mirror each other +1.5,-1.5. The only part I haven't swapped is the transmision. My bellhousing is dialed in both on center and square to the crank within .005". Sounds very similar. My bet (though I've never seen it) is the problem lies inthe outputshaft/tailshaft area.
Doug
Re: vibration update on the cuda #126927
09/28/08 09:22 AM
09/28/08 09:22 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
maybe the nut behind the wheel needs to be tightened
thats is Fred you don't get anymore pix with Andrea LMAO
Re: vibration update on the cuda [Re: dvw] #126928
09/28/08 09:24 AM
09/28/08 09:24 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
Doug
do you still have this problem?
Re: vibration update on the cuda [Re: cudadan] #126929
09/28/08 09:42 AM
09/28/08 09:42 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
i think the rpms are around 5200 at 80, this is with 4.30s
That can't be right unless your converter is slipping real bad or your tires are about 20" tall. Should be well over 100 MPH at 5200 rpm.
the only other part that i didnt change was the flex plate. it is a b&m externally balanced pc. i didnt see any cracks and it didnt look to be bent. the converter holes lined up perfect also
Any chance it lost a balance weight?
Re: vibration update on the cuda [Re: GomangoCuda] #126930
09/28/08 10:34 AM
09/28/08 10:34 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
thats why i said i think lol there are no weights on the converter. i just got the converter back from getting a freshening up too
Re: vibration update on the cuda [Re: cudadan] #126931
09/28/08 10:38 AM
09/28/08 10:38 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
im just hoping that its not the motor somehow
Re: vibration update on the cuda [Re: cudadan] #126932
09/28/08 10:49 AM
09/28/08 10:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I thought the 360 converter had a weight welded
on it to compensate for the crank weight
Re: vibration update on the cuda [Re: MR_P_BODY] #126933
09/28/08 11:22 AM
09/28/08 11:22 AM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
the b&m flex plate takes car of that, it has a big half moon cut out of it
Re: vibration update on the cuda [Re: cudadan] #126934
09/28/08 12:07 PM
09/28/08 12:07 PM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
Are the input and output shaft in the trans the same or were they changed? I have a friend that had a vibration problem with his chevy. It turned out to be a slighly bent input shaft in the trans. Next time the trans is apart put the shafts between centers and check them.
Re: vibration update on the cuda [Re: cudadan] #126935
09/28/08 12:14 PM
09/28/08 12:14 PM
That B&M flexplate cold be it, I've had problems with mine and other people on this site have too.
Re: vibration update on the cuda [Re: GomangoCuda] #126936
09/28/08 12:20 PM
09/28/08 12:20 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
They don't add weight to them , they remove the required amount of weight 180* off from where you need to add the weight to get the desired result .
Re: vibration update on the cuda #126937
09/28/08 12:20 PM
09/28/08 12:20 PM
JohnRR Offline
JohnRR  Offline
Good point Mike , I'd take the flexpalte to a machine shop and have it checked .
Re: vibration update on the cuda [Re: cudadan] #126938
09/28/08 12:36 PM
09/28/08 12:36 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Why was the transmission rebuilt? Could be a bent main shaft.
Did you change the stock pinion angle? If so, how did you do it?
Re: vibration update on the cuda [Re: cudadan] #126939
09/28/08 12:37 PM
09/28/08 12:37 PM
The Sunny Shuswap
dodgefarmer Offline
dodgefarmer  Offline
The Sunny Shuswap
Bushing replaced in tailshaft housing? Also hows the tranny mount?
Randy
Re: vibration update on the cuda [Re: JohnRR] #126940
09/28/08 12:37 PM
09/28/08 12:37 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
the flex plate is my next try, just sux im gonna pull the trans again, but i am really getting good at it LOL
i really appreciate all the feed back guys
Re: vibration update on the cuda [Re: B1HEAD_USER] #126941
09/28/08 12:38 PM
09/28/08 12:38 PM
Stratford nj
cudadan Offline OP
cudadan  Offline OP
Stratford nj
they both have been changed, the only thing thats the same is the housing itself, even changed the tail housing
Re: vibration update on the cuda [Re: cudadan] #126942
09/28/08 01:05 PM
09/28/08 01:05 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Bust your u-bolts loose and check the spring perches. I had one come loose on mine. After putting in a new driveshaft and fixing the sprag I drove the car and it drove like crap. However, everything passed the visual check. The weld had a hairline on it that didn't look like anything. Removing the u-bolts showed it was busted completly loose from the housing. Could be your pinion angle is going wild when going down the road, and returns to normal when under no load(due to a busted perch).
Would be an easy check before pulling the trans.
68 Barracuda Formula S 340
Re: vibration update on the cuda [Re: Bad340fish] #126943
09/28/08 01:24 PM
09/28/08 01:24 PM
Illinois
493_Scamp Offline
super gas
493_Scamp  Offline
super gas
Illinois
I would run it without a shaft.Make a dummy plug out of an old yoke and a plate to keep it from backing out. Run the car at the rpm it vibrates and shift 2-3 a couple times.Remember not to hit park,just shut it off. What happened to the original front drum? Did the bushings and washers look ok? Hows the end play?
