will 18x10's fit on my 71 roadrunner? #1268953
07/16/12 09:06 PM
07/16/12 09:06 PM
roadrunner440 Offline OP
Can anyone give me some info on what needs to be done to install 18x10 rims and 295 tires on my 71 roadrunner!
Re: will 18x10's fit on my 71 roadrunner? [Re: roadrunner440] #1268954
07/16/12 09:14 PM
07/16/12 09:14 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Buy some new lug nuts to go with the new wheels..
I am truckless..
Re: will 18x10's fit on my 71 roadrunner? [Re: 340SHORTY] #1268955
07/16/12 10:07 PM
07/16/12 10:07 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
running 18x 9.5. it is super tight. not sure if it will work with 10" wheel. running 28 12 18 MT sprtsmans
Re: will 18x10's fit on my 71 roadrunner? [Re: hemibeep] #1268956
07/17/12 02:31 PM
07/17/12 02:31 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
I'm surE a few folks have made those fit with 15x10, but15X10 is a bit more. I'm kinda curious now myself as I have a 1972 charger and looking at a similar sized wheel for the car.
Re: will 18x10's fit on my 71 roadrunner? [Re: roadrunner440] #1268957
07/17/12 02:35 PM
07/17/12 02:35 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I have 18 x 10 WHEELS on the hot rod. There was room for 15 x 10 WHEELS on my 74 Road Runner too.
It's all about the backspacing.
- Stu Harmon
Re: will 18x10's fit on my 71 roadrunner? [Re: feets] #1268958
07/19/12 01:54 AM
07/19/12 01:54 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Your gonna get 18x10's to fit way easier than 15x10, cause there's no sidewall bulge. I had my 17x11's on my buddy's 71 RR, it was tight but it had the right offset also.
Re: will 18x10's fit on my 71 roadrunner? [Re: 77ProStreet] #1268959
07/19/12 04:51 PM
07/19/12 04:51 PM
did you move the rear springs in? what wheel and off set did you use?
Re: will 18x10's fit on my 71 roadrunner? [Re: roadrunner440] #1268960
07/19/12 11:12 PM
07/19/12 11:12 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
18x10s all the way. Move the springs in, get the offset right and it's good.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: will 18x10's fit on my 71 roadrunner? [Re: dfsmopars] #1268961
07/20/12 07:45 AM
07/20/12 07:45 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
The Charger has more space than the Roadrunner. The combo i ran on my 72 Charger (15x8 steelie w 295/50-15) wouldn't work at all on the 72 Satellite, front or back. I figured they would. Disappointing... because it sure looked mean...
I should have known... as all those old Nascar Charger pics look pretty stock, metal-wise, where all the 71-2 Roadrunner pics have the wells cut out at the body line... a LOT ov missing metal.
Still... i can fit 18x10's easy on my 70 Challenger... which has to be smaller than a 71-2 B-body, even the smaller one? You should have no problems... just takes a LOT ov messing around, mocking up and finding the perfect backspace.
Re: will 18x10's fit on my 71 roadrunner? [Re: roadrunner440] #1268962
07/20/12 02:50 PM
07/20/12 02:50 PM
fiddlerfingers Offline
I'm running 20X10 on my 71 RR and there is plenty of room. No relocation of the spring mounts leaves about 3/8 inch between wheel and spring. Like stated above its all in the back spacing of the rim. I used a 4.5 inch back space.
Re: will 18x10's fit on my 71 roadrunner? [Re: Pale_Roader] #1268963
07/20/12 10:49 PM
07/20/12 10:49 PM
We meet again. talked to you at bowling green. Tryed to contact Dr. Diff but not reply so far. You going to be at columbus?
Re: will 18x10's fit on my 71 roadrunner? [Re: fiddlerfingers] #1268964
07/20/12 11:11 PM
07/20/12 11:11 PM
Silsbee,Tx
-Cuda Offline
-Cuda  Offline
Silsbee,Tx
Got pics? I'd think they'd work on my 73.
Re: will 18x10's fit on my 71 roadrunner? [Re: roadrunner440] #1268965
07/21/12 12:16 AM
07/21/12 12:16 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you haven't heard back from me, you are probably not calling during business hours, or you are misspelling my E-mail address.
doctordiff@gmail.com
(406)883-4772 10-6 Mountain Time, M-F
Re: will 18x10's fit on my 71 roadrunner? [Re: roadrunner440] #1268966
07/21/12 01:28 PM
07/21/12 01:28 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I plan on it.
