Re: 1st gear adjustment on a 727
[Re: fox]
#1268933
07/16/12 09:53 PM
07/16/12 09:53 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
Not all converters are the same. Talk to your converter guy. Don't buy an off the self converter! There are a couple of converter builders here who can answer this for you and build something better for you. ( it won't be a $100 converter either)
it was 500 and custom built.
[Re: mikemee1331]
#1268935
07/17/12 01:26 AM
07/17/12 01:26 AM
Posts: 1,759 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
So if you do cough up the $$$ on a custom converter (which I did), what is the best way to judge/evaluate whether the place delivered?
In my example, I am supposed to have a 2800-3200 stall converter behind a decently built 360 motor (727 trans, 3.91 SG).
Car is finally ready to hit the street, so as I take some initial runs what do I look at to really figure out if the converter is built correctly? What I mean is this: a wild mash of the pedal to the floor will allow the RPMs to jump up, right up to around the stall speed...but when is the converter too loose at the lower RPM? Mine starts to move the car right away, and at part throttle, the RPMs do not flare up...I judge that to mean it's doing it's job well.
In fact, I think my trans shift too quick into 1st and 2nd...but that's due to the governor weights, which I'm guessing are not the correct for the higher RPM I wish to see.
[Re: mikemee1331]
#1268936
07/17/12 08:22 AM
07/17/12 08:22 AM
Posts: 541 chatham, Ilinois
fox
super street
super street
chatham, Ilinois
There are differences between a 12" 2800 ztall and say a 9.5" 2800 stall. again ask these questions with the builder of the converter and follow the advice. They have forgotten more than I know about converters. I know a converter "Stall rating" Is fooor YOUR application. If you order a 2800 converter and it 'stalls' close to that,, then you use it behind a stock slant 6 it will be much lower in stall. Also there are three 'stall speeds' in each converter. Ask that question to learn more from him/her.
[Re: 135sohc]
#1268937
07/17/12 06:35 PM
07/17/12 06:35 PM
mikemee1331
bethlehem pa
You went from a relatively 'tight' stock converter to one with a much higher amount of 'slippage'. Its going to be annoying until you get used to it.
i think this covers about 90% of the issue. thanks guys and JohnRR, i didn't think there was, i was just hoping. thanks for the PM also! some of the issue may also be the shift lever on the trans. i've noticed now that it shifts almost right away into 3rd. with the tighter converter i didn't really notice. the converter is a 9.5 BTW.
