??? How much does the heat mess up your 1/4 mle time??
#1268910
07/16/12 07:45 PM
07/16/12 07:45 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Well my friend came home from working over seas for the last year and wanted to go racing. So we loaded up my dart and went racing last Saturday night.well that nite the temp was not bad around 70-71 degrees. But the humidity was down right nasty. Oh also for got to add that we did not start racing until 12 am. It was so bad that every body was fighting to keep there windshield dry and not fog up. Well any way here are my 1/4 times. all of these were done on 93 pump gas. 11.03 at 122 mph 1.56 60 foot 11.01 at 122 1.56 10.91 at 122.5 1.55 10.98 at 121.8 1.60 11.01 at 121.0 1.60 i think i spun a little bit on most of the passes and the track was going away on the last two passes. But i am down 2 mph in the 1/8 and around 3 mph in the 1/4 from what i ran last fall which was a best of 10.68 at 125. So is it normal to loose as much as i did in the heat or is my car just slow in the heat. Thanks For your time. Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
Re: ??? How much does the heat mess up your 1/4 mle time??
[Re: mopar65]
#1268911
07/16/12 08:06 PM
07/16/12 08:06 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Two to three tenths in real hot heat and humidity is not bad compared to a nice cool 60 degree day with no humidity. I have not run my new combo much but my old combo ran a best of 11.49 in cool air and would run 11.70's in the heat. 50's and 60's on decent days. I remember on a hot June day I ran from 11.74 to 11.78. It would also drop 2 or 3 mph. If you drop alot of et on hotter days you may be to fat on the carb. Ron
[Re: Dago Red]
#1268916
07/17/12 09:05 AM
07/17/12 09:05 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
As a rule of thumb, a well prepped drag car on gas will change about .01 per 200 ft DA change. My Dart on Alcohol changes much less, about .01 per 400 ft DA change. All this depends on tuneup and traction of course. On a really hot day I expect to lose some 60 ft.
[Re: Mr.Yuck]
#1268918
07/17/12 10:48 AM
07/17/12 10:48 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Idon't have much seat time in this car but hot weather usually takes 2-3 tenths from a car. You can be more consistant if you run a cool can, but I think it will still slow down some.
I dont even think those cool cans from years back are legal anymore... different fuels will make it less susceptible to heat changes.... my car only changes a couple hundredths max on E-85
[Re: gregsdart]
#1268919
07/17/12 11:20 AM
07/17/12 11:20 AM
Posts: 12,394 Taxes & Virus's R-US, NY
Dragula
Well, mine went 6.58 in the cooler morning and then 6.47 in the heat last week! MPH got better too! I will let you guys figure that one out.
Temp was reading 99* in the sun, 88* in the shade. Launch rpm, shift rpm, everything pretty much the same.
The 6.58, the motor was still not fully heat soaked, and the 60ft was off thanks to the burn out. Typically its a 6.52, which is what the 2nd pass was, but we did not expect to dip all the way down to 6.47 on a hot day. The next couple of passes, the car just got faster on every pass with no changes on my end, just getting a better burn out than the 1st pass and trying to be consistent with motor launch temps. Motor is still a little tight, and the chassis might be as well. So in the heat of the day it was right around 6.49, then it cooled down a little to about 83* and we got the 6.47.. The car's record was 6.44 on a nice cool night so, not bad in the heat. We run pump gas, and i think it changes more than it really should, but we are still learning with 90 actual full passes on the car now.
[Re: mopar65]
#1268922
07/17/12 12:33 PM
07/17/12 12:33 PM
gregsdart
The Density altitude is a measure of available oxygen to use. Humidity, temp and barometric pressure are all taken into account to arrive at the Density altitude number. So it doesn't exactly measure altitude, but a combination of the effects of all three. I have found the Walace calculator for converting to zero altitude to be generous. My car doesn't change as much as the category I am in.
[Re: Dragula]
#1268923
07/17/12 01:00 PM
07/17/12 01:00 PM
383man
Balt. Md
The first pass was slower ey ? Was the eng warm enough or did it spin. Alot of times if a car gets faster in hotter air it may be a little lean. Ron
[Re: 383man]
#1268924
07/17/12 04:17 PM
07/17/12 04:17 PM
MR_P_BODY
Might be lean.... but also the first pass of the day for me is usually a bit slow...due to all the parts and fluids not warmed up all the way... even warming it up in the pits(I tend to drive around to warm it up)
[Re: MR_P_BODY]
#1268925
07/17/12 09:35 PM
07/17/12 09:35 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Don't have DA #'s but in cool, crisp mineshaft air (Atco) I would run 2-3 tenths quicker, and 2-3 mph faster than I have been in the heat and humidity lately.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Dads426]
#1268928
07/19/12 12:08 AM
07/19/12 12:08 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Atco or Cecil when the air is good yields great times. Went our best of 9.94 at 135 at Cecil in less than ideal conditions (hot, but dry) and 10.11 at MIR in high heat/humidity.
Jeff - I bet you still have an old cool can...
Only "cool can" I have bro is the Bud in my hand... Mark (Chris' Brother) still uses one.
