F 8 GREEN 1969 ROADRUNNER #1268879
07/16/12 06:43 PM
07/16/12 06:43 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
Looking for a PPG formula that will match the factory paint.I had a omni formula and a prophet formula neither was close enough.
Re: F 8 GREEN 1969 ROADRUNNER [Re: runner12] #1268880
07/16/12 06:58 PM
07/16/12 06:58 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
my car is painted in PPG and I checked it (and Dupont) in Base/Clear vs. an untouched sample from my front window channel; I was pleased with the match.
PPG's code is 43786 but I'm unclear if it is the same number in every paint line they have.
http://paintref.com/cgi-bin/chipdisplay....fo=&page=10
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: F 8 GREEN 1969 ROADRUNNER [Re: DPelletier] #1268881
07/17/12 12:40 PM
07/17/12 12:40 PM
Washington, Pa
runner12 Offline OP
runner12  Offline OP
Washington, Pa
I had a sample made of that and it not close enough tip the piece I have. Thanks
Re: F 8 GREEN 1969 ROADRUNNER [Re: runner12] #1268882
07/17/12 01:28 PM
07/17/12 01:28 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
It seems every paint match you've had made doesn't match? ....are you using the same guy to do the mixes/spray outs?
I've seen my share of bad/inexperienced paint mixers over the years
and if that's not the problem, what value shade/base are you spraying over?...a lot of variables when it comes to painting...color can be so influenced by base shade/value, coverage, technique, etc, etc
Mike
Re: F 8 GREEN 1969 ROADRUNNER [Re: runner12] #1268883
07/17/12 02:17 PM
07/17/12 02:17 PM
DPelletier Offline
DPelletier  Offline
Are you sure the pce you have is a) original and b) unfaded?
Re: F 8 GREEN 1969 ROADRUNNER [Re: DPelletier] #1268884
07/17/12 06:05 PM
07/17/12 06:05 PM
DPelletier Offline
DPelletier  Offline
Why don't you ask Domingo what he used?
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
