Correct paint for '73 Dart Sport Snorkle scoop #1268857
07/16/12 05:34 PM
07/16/12 05:34 PM
western pennsylvania
b1dartsport Offline OP
Just got car back from the body shop,it has the triangular satin black stripe from nose of car to cowl. Trying to find the correct paint to match the scoop with the decal. This is for my Drag car. I am installing the 4.5" twin snorkle from AAR fiberglass to give the carb & Indy intake some clearance but I'm trying to keep it as stock appearing as possible. Thanks in advance for any help-Randy
Re: Correct paint for '73 Dart Sport Snorkle scoop [Re: b1dartsport] #1268858
07/16/12 10:46 PM
07/16/12 10:46 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
the a body snorkel scoop wasn't paint from the factory. Just black gel coat I believe.
Re: Correct paint for '73 Dart Sport Snorkle scoop [Re: AdamR] #1268859
07/16/12 10:55 PM
07/16/12 10:55 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I painted mine Organisol years ago.
Re: Correct paint for '73 Dart Sport Snorkle scoop [Re: RJS] #1268860
07/17/12 08:44 AM
07/17/12 08:44 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Re: Correct paint for '73 Dart Sport Snorkle scoop [Re: AdamR] #1268861
07/17/12 12:14 PM
07/17/12 12:14 PM
Winnipeg
O
OneOfMany Offline
OneOfMany  Offline
O
Winnipeg
Hmmm.. On FABO I answered this question similar to you Adam, and I was told flat out I was wrong. Is it actually not painted then?
Grant
Re: Correct paint for '73 Dart Sport Snorkle scoop [Re: OneOfMany] #1268862
07/17/12 12:20 PM
07/17/12 12:20 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I had one of those many years ago and it was white, not black.
100% completely unpainted white smooth finish
Re: Correct paint for '73 Dart Sport Snorkle scoop [Re: OneOfMany] #1268863
07/17/12 01:59 PM
07/17/12 01:59 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
Grant
I always figured they were painted till Scott said otherwise. For the record Ive never owned an original scoop and I would probably paint it if I did.
Re: Correct paint for '73 Dart Sport Snorkle scoop [Re: AdamR] #1268864
07/17/12 06:15 PM
07/17/12 06:15 PM
The scoop I got from AAR is gray colored jell coat. I just think it would be best to match the finish of the satin black stripes on the side of the car and the large satin black decal on the hood.
