Re: Frt wheels...3.5 or 4 ?
[Re: cagebob1]
#1268290
07/15/12 04:55 PM
07/15/12 04:55 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Been beating 3 1/2`s on the street/strip for years so race only should be more than fine w/the right tires as stated..........
[Re: cagebob1]
#1268291
07/15/12 05:03 PM
07/15/12 05:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok then...let's expand the original question...does tire size have a direct effect on performance/handling? other than rollout?
A wide tire on a narrow rim gives you a lot of side wall roll if you get crossed up where the narrower tire on the same rim will feel more stable
[Re: SLOW67]
#1268293
07/16/12 10:58 PM
07/16/12 10:58 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
The choice of tall, skinny, radial, 15" tires seems to be dwindling at a rapid pace, so I prefer the 4" wheel. Seems like you are stuck with the short VW style 165-175, or you have to jump all the way to 215/70 which is what are on my 4" centerlines and bulge quite a bit.
Just read, "Track only light weight race car", go 3 1/2, with as much out set as possible so they can clear whatever brakes you end up with.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1268294
07/16/12 11:18 PM
07/16/12 11:18 PM
MR_P_BODY
Most light weight front wheels only offer 2 back spacing wheels... 1.75 and 2.25... I always prefer the deeper off set.. it gets the center line of the tire closer to the center line of the ball joints to decrease the brake torque when you are on the brakes
