side glass install #1268268
07/15/12 03:24 PM
07/15/12 03:24 PM
Winnipeg,Manitoba
cudablues Offline OP
Winnipeg,Manitoba
Any tricks or ideas on how to put the side door glass in on a 70 Roadrunner?The vent frames are in and the rear vertical channel is sitting loose in the door.Also can the cat whiskers go on after the glass?Looks like the whiskers slide down over the elongated holes,which looks doable with the glass in,but not sure Thanks
Re: side glass install [Re: cudablues] #1268269
07/16/12 11:39 AM
07/16/12 11:39 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Did you take the glass out ?? I am doing a 70 Sport Satellite and took mine apart . . . so hoping they will go in fairly easily. I believe the cat whiskers will go in after you have the glass installed. Good luck . . . I am not looking forward to the rear window regulators - arrghhhh . . .
Mark
Re: side glass install [Re: a12rag] #1268270
07/17/12 09:14 AM
07/17/12 09:14 AM
Winnipeg,Manitoba
Winnipeg,Manitoba
Bought the car in pieces.I got one side in.PITA.Think i did a lot of ad libbing with it.Be real careful of the plastic pieces on the front edge of the glass.
