1971 e body ignition key cylinder replacement #1268251
07/15/12 02:47 PM
07/15/12 02:47 PM
CT
1932chrysler Offline OP
CT
Is there any easy way to remove the ignition switch lock cylinder without having to take the whole column apart (lock plate, bearing)
1932 Chrysler CI Sedan
1956 Pontiac Catalina Sedan
All Makes & Models Are Special
Re: 1971 e body ignition key cylinder replacement [Re: 1932chrysler] #1268252
07/15/12 02:54 PM
07/15/12 02:54 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Nope. sorry
Re: 1971 e body ignition key cylinder replacement [Re: 1932chrysler] #1268253
07/15/12 03:08 PM
07/15/12 03:08 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I can't remember right now, but I think it can be replaced without taking the whole thing apart...the lock cylinder.
Re: 1971 e body ignition key cylinder replacement [Re: Challenger 1] #1268254
07/22/12 11:10 PM
07/22/12 11:10 PM
CT
CT
Thank you for the photos
I replaced the key cylinder I only had to
Remove steering wheel
Disconnect turn signal harness connector pull turn signal switch up and let it hang
remove turn signal housing let it hang
remove plate to access hole to release key cylinder
Re: 1971 e body ignition key cylinder replacement [Re: Challenger 1] #1268255
07/23/12 02:06 AM
07/23/12 02:06 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Where did you get the holding fixture?
Re: 1971 e body ignition key cylinder replacement [Re: Snoopy] #1268256
07/23/12 05:03 AM
07/23/12 05:03 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
That photo is actually Gary's (Challenger1) & he's commented about it before, the plate just happened to fit....
Re: 1971 e body ignition key cylinder replacement [Re: 1_WILD_RT] #1268257
07/23/12 11:24 AM
07/23/12 11:24 AM
Cincinnati, Ohio
Cincinnati, Ohio
It's a broken Mark Williams floater housing mount that I used, anything would work with 2 holes in it to mount the coluum to.
Glad to hear you got yours replaced 1932 Chryler.
