440-6 fan........ #1268051
07/15/12 01:17 AM
07/15/12 01:17 AM
Colorado Springs,Colorado
Roadrunner440-6 Offline OP
What is the correct fan used on a 1970 440-6 motor? This has the 4:10 rear and 4 speed combo. Any help will be greatly appreciated. Thanks
Re: 440-6 fan........ [Re: Roadrunner440-6] #1268052
07/15/12 01:22 AM
07/15/12 01:22 AM
iowa
copchaser Offline
copchaser  Offline
iowa
7 blade, with fan clutch.
Re: 440-6 fan........ [Re: copchaser] #1268053
07/15/12 01:54 AM
07/15/12 01:54 AM
did it matter if it was an automatic of manual?...was the torque fan only used on sixpacks or was it used on all big blocks...? just trying to get educated on this fan. ..........also.....what is the purpose of this fan?
Re: 440-6 fan........ [Re: Roadrunner440-6] #1268054
07/15/12 01:57 AM
07/15/12 01:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Same fan stick or auto , same fan used on all big blocks with max cooling.
Purpose of the fan ... to keep the engine cool by helping to pull air thru the radiator at low speeds.
Re: 440-6 fan........ [Re: JohnRR] #1268055
07/15/12 02:17 AM
07/15/12 02:17 AM
Thanks!
Re: 440-6 fan........ [Re: Roadrunner440-6] #1268056
07/15/12 03:48 AM
07/15/12 03:48 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If we're talking Superbird, it would be a fixed fan
Re: 440-6 fan........ [Re: DAYCLONA] #1268057
07/15/12 12:41 PM
07/15/12 12:41 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Yeah, that would be a challenge...
Re: 440-6 fan........ [Re: RSNOMO] #1268058
07/15/12 03:18 PM
07/15/12 03:18 PM
grand rapids mi. usa
P
Purestocker Offline
Purestocker  Offline
P
Automatic cars without low gear could come with a 22" radiator and a fixed blade fan but with a four speed you got the 26" radiator and the clutch type fan.
Re: 440-6 fan........ [Re: Purestocker] #1268059
07/15/12 07:17 PM
07/15/12 07:17 PM
Valley of the sun, AZ
2
2JcodeChargers Offline
If you are chasing part numbers, I believe you would be looking for a "216" fan and an "070" clutch. If you have your broadcast sheet you can look at the numbers on it but I think those a 99% sure thing.
Sounds like a cool car. Hope you share some pictures when you have it done.
Re: 440-6 fan........ [Re: 2JcodeChargers] #1268060
07/15/12 09:23 PM
07/15/12 09:23 PM
Thanks......that will get me in the right direction...
Re: 440-6 fan........ [Re: Roadrunner440-6] #1268061
07/16/12 01:04 AM
07/16/12 01:04 AM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
The fans are cheap a 070 clutch will cost some $$$
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 440-6 fan........ [Re: JohnRR] #1268062
07/16/12 01:26 PM
07/16/12 01:26 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
True, but not all 440-6's got max cooling; that was an axle package thing (and of course, all 4spds got an axle package)
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 440-6 fan........ [Re: DPelletier] #1268063
07/17/12 12:13 PM
07/17/12 12:13 PM
Montgomery, Alabama
RusTy/SE Offline
RusTy/SE  Offline
Montgomery, Alabama
Is the power steering cooler also standard on the Axle Packages?
Re: 440-6 fan........ [Re: RusTy/SE] #1268064
07/20/12 01:10 AM
07/20/12 01:10 AM
how do you know if your clutch fan is bad?
Re: 440-6 fan........ [Re: Roadrunner440-6] #1268065
07/20/12 01:30 AM
07/20/12 01:30 AM
was there suppose to be a cover in front? when looking at mine you can see the spring. I've seen pictures of others with the visible spring and others with a cover?
Re: 440-6 fan........ [Re: Roadrunner440-6] #1268066
07/20/12 01:45 AM
07/20/12 01:45 AM
