340 temp #1267974
07/14/12 11:16 PM
07/14/12 11:16 PM
Huntertown, IN U.S.A
abodyfan Offline OP
abodyfan  Offline OP
I recently found that my factory guage was 35-40 degrees off. My mechanical gauge shows 190-215 degrees. My question is does this seem right? Still to high? The engine is 350-400 horse. I'm using a champion 22in. 3 core radiator with a 17in fan with shroud. Thanks for your help.
1971 Dodge Demon 340 4-speed 1970 Plymouth Duster FM3 340 727 1968 Dodge Dart GT Convertible
Re: 340 temp [Re: abodyfan] #1267975
07/15/12 12:31 AM
07/15/12 12:31 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
Are you using a new temp sending unit with you factory gauge? Try an old original unit. I've heard some of the units have the incorrect resistance.
I've got a 22 Champion in my 425-450 HP 416 stroker motor. And it's at 160-180. And it doesn't have a shroud yet. If it idles for quite a while the lack of front airflow will get it up to 200-220.
