Re: 408 cam
[Re: bill8121]
#1267890
07/14/12 07:15 PM
07/14/12 07:15 PM
Posts: 20,832 A collage of whims
topside
A collage of whims
Did a 406" SB for my '74 Duster (A/C, 3.21 gear, stock converter, iron heads, 9:1, street car) using an Engle hyd flat-tappet with 214/224 @ .050 and .470/.504 lift. Ran great, tons of torque, great throttle response (T-quad), 17MPG @ 70, and sounded quite healthy.
Re: 408 cam
[Re: bill8121]
#1267891
07/14/12 07:23 PM
07/14/12 07:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
First timmer in this section. I'm gonna purchase a 408pair short block from muscle motors. I want a stupid fast street truck, 3800 lbs. I have j heads that I'm gonna send to get some work done on but my dilemma is cam selection. Being that it's a truck i need lots of torque. Also what stall converter/gears/carb?
If you want stupid fast your using the wrong heads... plenty of different heads will make way more power... then get the heads ported and have the cam picked based on the head flow and lift
Re: 408 cam
[Re: MR_P_BODY]
#1267892
07/14/12 07:39 PM
07/14/12 07:39 PM
moparpollack
Lil Herman
Lil Herman
85086
Check out Brian OU812 from IMM RHS heads for the street.
Re: 408 cam
[Re: bill8121]
#1267896
07/14/12 09:35 PM
07/14/12 09:35 PM
MR_P_BODY
How much compression can i run on pump gas?
Depends what you have for pump gas but 11:1 is about it
