Re: MuuMuu's 68 Dart... It's a Learning Process...
[Re: MuuMuu101]
#1267599
03/29/14 03:17 PM
03/29/14 03:17 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I wasn't really very impressed with Rockauto stuff, either. I was going with them to try to do my car inexpensively, then I went out and bougt an expensive disk brake setup and a bunch of stainless lines and my budget was shot to he!! . Oops.
I like getting stuff from them because usually I'm in class or at work when the parts stores are open. So it's easier for me to buy them and have them shipped to my house. Plus, every time I go to the parts stores, they almost always don't have my parts and rockauto ends up having them (usually cheaper even after shipping).
Anyways, Thursday I spent a good amount of time with a wire brush scraping off all the old grease and dirt off the 8 3/4 rear end. It's starting to look pretty nice now. I also bought drum brake tools so I'll post pics of everything after I finish the brakes up.
Progress is a good thing! I am itching to get back on mine, and there is some small stuff I want to start doing to the Dart.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: MuuMuu101]
#1267601
06/02/14 04:09 AM
06/02/14 04:09 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Ok, so it's update time. The update is I haven't done anything yet because school and my internship take up 95% of my time. But good news, school finishes in a week; however, I may be working full time this summer. Which is good and bad because it means more money but less time. So, I still have the TVS sitting in my garage awaiting to be put in. Only problem is I need a welder (may have to go shopping in a couple weeks) to install all the little brackets here and there. I was also thinking, I might as well go bbp and big disc brakes on all 4 corners. So to do this I was thinking about going Dr Diff 13" Brembos on the front and 11.7" Cobra on the back. Only thing is I'd need new axles and probably a new carrier that's more fun (like 3.55 or 3.91s with a Eaton TrueTrac). For wheels I already know what size I'm going to go with and I know what tire I'd like to use. My thing is, I really don't know what the most cost effective way of doing this is. Is it doable to take apart and assemble a differential in my garage or is it best to send it out? Also, there's the question of buying a new carrier or just getting the ring and pinion with the diff separately and installing it into my carrier? The suspension doesn't seem too hard nor does the disc brakes. I'm for sure, at the base minimum going to need to fix my head on the 273 unless it's something worse. Then I'll have to replace it. There's also little odds and ends here and there. But if possible I'd like to get all that done over the summer. A friend from work offered to help any time and I may have another friend who may help later on in the summer. All of the parts though is going to set me back quite a few thousands of dollars (maybe $6-8k depending on how I do it) but the Dart should be a more fun car after that.
[Re: MuuMuu101]
#1267602
06/18/14 03:24 AM
06/18/14 03:24 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Well, I got some progress done Saturday and today. I tore apart my 8 3/4 and am getting it ready for a rebuild. It's the first time I've ever done something like that and I'm happy I was able to do it alone. I'm slowly facing my anxiety complex. Anyways, I've got it down to a bear housing. The carrier was a bit tricky pulling out on my own and I accidentally spilled almost all the spare diff oil. Now the next step is to clean the housing and get it painted or powdercoated before a friend of mine reassembles it. I just am not sure how at the moment. But, once it's powdercoated new bearings, bbp axles, 3.55 gears, and a Eaton TrueTrac is going in. My friend has been rebuilding 8 3/4 for 30 years or so, so I'll have him put it together. While he's doing that, I'll order my brake kits from Dr Diff. Once that's installed I'll be able to measure my custom wheels and hopefully get a 275/35/18 to fit all the way around. My goal is to get rear end, brakes, wheels, tires, and Hotchkis TVS done by the last weekend in September. If there's time and money, maybe a new engine and/or trans will go in. This GT is going to stand for something new, "Gran Turismo." I'm excited!
[Re: MuuMuu101]
#1267610
08/16/14 02:06 AM
08/16/14 02:06 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
So, things are finally moving with the Dart. First things first, I bought a sweet flip top gas cap from a FABO member that I hope to put on my Dart with an adapter ( http://fliptopcapadapter.com/about.html )... Next on the list... I purchased the Dr Diff front and rear brake kit. I got the 13" rotors up front with the Brembo looking calipers and in the rears I got the 11.7" kit with the Mustang calipers. Rough mach up of what the fronts would look like: Today I did a lot of work putting the 8 3/4 together. In the past weeks I've managed to install the carrier onto the housing. Today I installed the axles, adjusted for play (with help from a friend), and bolted on the brakes. I still need to do lines but was tired and gave up for the night. Ignore the mess... So, hopefully during the week I can manage and finish up the lines. Next weekend, I guess, would be the start of installing the front brakes and Hotchkis TVS. It's kind of a scary thought. I definitely don't want this to be one of those eternal never ending products. I need to get the car driving again (after the suspension, brakes, wheels, and tires replaced) before the start of October. I think it's doable. I may need some help along the way.
[Re: 68KillerBee]
#1267612
08/17/14 09:42 PM
08/17/14 09:42 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Keep it up! Glad you stuck with this car and hopefully you get it going quick. If only you were closer, I would help. Just keep plugging away at it.
Thanks. I've never thought about selling it. Just trying to keep it moving. I'm still a little bummed I won't be able to work on getting a better engine and trans in there for another year or so, though. Still thinking about options for that.
Anyways, I got my flip top gas cap adapter last week. Unfortunately, I thought it would be a bolt-in application but I'm going to have to do some work. I've got a 3 bolt mounting surface for my gas cap and a 4 bolt mounting surface on the quarter panel. I also have to drill in holes into the spacer (which I assumed would be drilled beforehand). Trying to think of the best way of doing this. The only instructions were a picture.
[Re: MuuMuu101]
#1267613
08/18/14 02:24 PM
08/18/14 02:24 PM
Posts: 2,757 Gilbertsville, PA 19525
Pntastar69
If you open the link at the bottom of your post, there is another link at the bottom. Here is that link http://www.forabodiesonly.com/mopar/showthread.php?t=53282It states to drill holes: 1.I placed the adapter on my cap. (with the cap open and on the bench) 2.Clamped it in place. 3. Drilled the 1st hole.4.Placed a screw through the hole. 5.Lined it up and clamped it again. 6. Proceed to drill the rest of the holes.7.Used the original screws that hold the filler neck to the Quarter panel to put it all back together.
[Re: MuuMuu101]
#1267617
09/06/14 06:44 PM
09/06/14 06:44 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Got a little more work done today. We finished the lines on the differential, installed the shocks, and torqued everything down. We were having trouble removing the lines from the distribution block up front. There's not much room to clear a wrench between the steering box and the exhaust. So, we may just end up cutting it and going over to the original idea of bringing the line around the frame rails and core support with a T-block. While we're at it we're going to have to redo the lines that go from the front to the rear to the car as they cross the path of the subframe connectors.
I also am going to start cleaning the LCA's sometime this week. I've still got to remove the strut rods (don't have the tooling to get enough torque to remove the nut), weld on a bumpstop bracket (the spot welds broke off), weld on the stiffening plates, and install the pin and bushings. Once the front lines are done, the front suspension can slowly be assembled.
All the work isn't going to get done before the September 25th, but hopefully we can finish it off before Fall Fling, October 25th.
