head light problems on 03 Neon #126721
09/26/08 08:29 PM
09/26/08 08:29 PM
Friendly, WV
wedgeheaded Offline OP
Friendly, WV
My wife just came in and said the headlights on her 03 Neon weren't working right. The parking lights work, the siganls work, the low beams don't work at all and the high beams only work if you hold the switch back. I'm guessing it's the switch but how do you get into it? Thanks guys.
Re: head light problems on 03 Neon [Re: wedgeheaded] #126722
09/27/08 07:06 AM
09/27/08 07:06 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
You unscrew the plastic around it.The switch is multi function.Ince the cover comes off its easy to take out.Not a bad job.Rocky
Chrysler Firepower
Re: head light problems on 03 Neon [Re: therocks] #126723
09/27/08 08:46 AM
09/27/08 08:46 AM
Friendly, WV
Friendly, WV
Not sure I understand. When you say, "the plastic around it" do you mean the pod at the end of the dimmer arm? It's right to tight left to loose I'm guessing? Advance has a replacement switch for $53.00 and I'm hopping it has some instructions but I'm not betting on it.
Re: head light problems on 03 Neon [Re: wedgeheaded] #126724
09/27/08 10:25 AM
09/27/08 10:25 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The plastic cover at the column end. Take a good logical look at it and you shouold be able to figure it out.
Re: head light problems on 03 Neon [Re: stumpy] #126725
09/27/08 11:11 AM
09/27/08 11:11 AM
Friendly, WV
Friendly, WV
I found a post on neon.org that even has some pics of the process. With a little luck and a big hammer I should be OK.
Re: head light problems on 03 Neon [Re: wedgeheaded] #126726
09/27/08 11:22 AM
09/27/08 11:22 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Small car small hammer. You don't want to scare it to death. LOL It really isn't a hard replacement.
