Re: head light problems on 03 Neon
[Re: wedgeheaded]
#126722
09/27/08 07:06 AM
09/27/08 07:06 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
You unscrew the plastic around it.The switch is multi function.Ince the cover comes off its easy to take out.Not a bad job.Rocky
Chrysler Firepower
[Re: therocks]
#126723
09/27/08 08:46 AM
09/27/08 08:46 AM
Posts: 1,581 Friendly, WV
wedgeheaded
Friendly, WV
Not sure I understand. When you say, "the plastic around it" do you mean the pod at the end of the dimmer arm? It's right to tight left to loose I'm guessing? Advance has a replacement switch for $53.00 and I'm hopping it has some instructions but I'm not betting on it.
[Re: stumpy]
#126725
09/27/08 11:11 AM
09/27/08 11:11 AM
wedgeheaded
Friendly, WV
The plastic cover at the column end. Take a good logical look at it and you shouold be able to figure it out.
I found a post on neon.org that even has some pics of the process. With a little luck and a big hammer I should be OK.
