360 Magnum converter weight set instuctions? #1267144
07/13/12 10:11 PM
07/13/12 10:11 PM
beleneagle Offline OP
Hi Guys! I just received a P5249843 360 magnum balance weight and positioning template package, and didn't get the template! Does anyone here happen to have a copy, or can tell me where the weights need to go?
Many Thanks
David
Re: 360 Magnum converter weight set instuctions? [Re: beleneagle] #1267145
07/14/12 02:44 AM
07/14/12 02:44 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The Mag uses a Zero Balance convertor meaning no weight the flexplate on the other hand has the weight
Just simply buy a stock flexplate or an aftermarket like B&M etc
Re: 360 Magnum converter weight set instuctions? [Re: beleneagle] #1267146
07/14/12 08:44 AM
07/14/12 08:44 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
Hi Guys! I just received a P5249843 magnum 360 balance weight and positioning template package, and didn't get the template! Does anyone here happen to have a copy, or can tell me where the weights need to go?
Many Thanks
David
i looked for my old template,but no such luck.send it back and get a new one or buy a weighted flex plate.b/m makes one for @ $80.00
Re: 360 Magnum converter weight set instuctions? [Re: mcmopars] #1267147
07/15/12 01:36 PM
07/15/12 01:36 PM
I found a set for the LA 360, is the weight placement the same? I know that the Magnum uses less weight. Buying a flexplate is out of the question right now, so I really need to know where the weights need to go......
David
Re: 360 Magnum converter weight set instuctions? [Re: beleneagle] #1267148
07/16/12 12:12 AM
07/16/12 12:12 AM
Hello? I would like the instructions. I did after all buy the weight kit from Moparts! Can't somebody help me, or is this gonna be just like Wal Mart?
I'm not buying a B&M flexplate, so please don't suggest it. I'm trying to get by with a little as possible, so that leaves the B&M out.
Re: 360 Magnum converter weight set instuctions? [Re: beleneagle] #1267149
07/16/12 02:38 AM
07/16/12 02:38 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
David, Why can't you use a stock 5.9 Magnum flexplate? Are you using a small pattern convertor?
I'm not a WalMart employee but I've done quite a few 5.9 Mag conversions & only trying to help.
Re: 360 Magnum converter weight set instuctions? [Re: BulletBob] #1267150
07/16/12 07:25 AM
07/16/12 07:25 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
hell o welcome to wal- mart. i would have called us mcdonalds if i were you. the magnum is weighted differant.good luck
Re: 360 Magnum converter weight set instuctions? [Re: mcmopars] #1267151
07/16/12 12:05 PM
07/16/12 12:05 PM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
hi david, i have the 2 sided original instruction sheet you need. send me a pm with your address and i will send it along. one side has the install directions and the other has the dimensions to weld the weights to the converter . thanks, ron
Re: 360 Magnum converter weight set instuctions? [Re: 1969ronnie] #1267152
07/17/12 12:41 AM
07/17/12 12:41 AM
Done! Thank you, Thank you, Thank you, and Thank you!
David
Re: 360 Magnum converter weight set instuctions? [Re: BulletBob] #1267153
07/17/12 01:05 AM
07/17/12 01:05 AM
I have the stock flexplate, but it is my understanding the converter had weights welded to them till they changed the flexplate in 96', and mine is a 94'. Since the engine that I'm replacing is a 318, I need to add the weights to the converter. Right? I'm running a 904 tranny for now.
David
Re: 360 Magnum converter weight set instuctions? [Re: beleneagle] #1267154
07/17/12 01:50 AM
07/17/12 01:50 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I didn't realize that the early 5.9 Mag uses a different crank
Re: 360 Magnum converter weight set instuctions? [Re: BulletBob] #1267155
07/17/12 01:38 PM
07/17/12 01:38 PM
No biggie Bob, but since we're at Mc Donalds, lets super size!
David
Re: 360 Magnum converter weight set instuctions? [Re: 1969ronnie] #1267156
07/17/12 03:37 PM
07/17/12 03:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Why not scan it and post it here for everybody to see?
Re: 360 Magnum converter weight set instuctions? [Re: John_Kunkel] #1267157
07/17/12 06:08 PM
07/17/12 06:08 PM
1969ronnie Offline
1969ronnie  Offline
hi david, mailed it out after lunch. as soon as i get a minute,i will scan it for you guys. thanks, ronnie
Re: 360 Magnum converter weight set instuctions? [Re: 1969ronnie] #1267158
07/18/12 01:15 AM
07/18/12 01:15 AM
Many thanks Ronnie! You da man!
David
Re: 360 Magnum converter weight set instuctions? [Re: beleneagle] #1267159
07/21/12 09:21 PM
07/21/12 09:21 PM
Hi guys, I received the correct instructions today. When I get a chance I'll see if my buddy can scan then so I can post them here. I found a couple of pictures of the factory set up that I can post if anyone is interested.....
Thanks Again Ronnie!
David
Re: 360 Magnum converter weight set instuctions? [Re: beleneagle] #1267160
07/22/12 03:53 PM
07/22/12 03:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Post all you've got.
Re: 360 Magnum converter weight set instuctions? [Re: John_Kunkel] #1267161
07/25/12 02:10 AM
07/25/12 02:10 AM
This is the diagram showing the proper placement of the weights.
David
Re: 360 Magnum converter weight set instuctions? [Re: beleneagle] #1267162
07/25/12 02:17 AM
07/25/12 02:17 AM
The instructions for diagram in the above post is in this attachment.
Here is a picture of the two different Magnum flexplates with the 360 on the right.
And here's a 360 LA flywheel drilling diagram..
David
Re: 360 Magnum converter weight set instuctions? [Re: beleneagle] #1267163
07/25/12 02:27 AM
07/25/12 02:27 AM
Here is mine after adding the weights (which are alot thicker than the single factory weight):
David
I hope this helps anyone crazy enough to do this (Like me)!
