What wiring harness are you other rodders using? #126633
09/26/08 06:10 PM
09/26/08 06:10 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
Does anybody know of a fairly priced solution for wiring?? I need a wiring harness or will need it for the mopar powered '46 ford pu. I need something that will work for a four headlight system. Any ideas or suggestions??
Re: What wiring harness are you other rodders using? [Re: DusterKrazy] #126634
09/26/08 06:47 PM
09/26/08 06:47 PM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
These guys seem reasonable and are the likely source for my next harness, plus they offer a lot of options for circuit size.
Reble Wire
Re: What wiring harness are you other rodders using? [Re: bohmer2] #126635
09/26/08 08:40 PM
09/26/08 08:40 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
I have bin looking off and on for one the main thing I don't like about some of the cheeper ones is there is no bulk head to go througth the firewall I guess they just want you to run the wires through a hole
Re: What wiring harness are you other rodders using? [Re: NoFrills] #126636
09/26/08 11:06 PM
09/26/08 11:06 PM
Imlay City, MI
DTT Offline
super gas
DTT  Offline
super gas
Imlay City, MI
In my 36' bare bones hot rod truck Im going to be using a kit from Rebel Wire....
http://www.rebelwire.com/
Glen is a stand up guy who is into cars, knows cars and is willing to help you out at all costs.
1978 Pro Street D100 1936 Dodge truck (Hot rod) 1957 Plymouth Plaza 1962 Chrysler 300 1964 Dodge 440 1995 Jeep Grand Cherokee 1971 Big Block Demon (Dads)
Re: What wiring harness are you other rodders using? [Re: DusterKrazy] #126637
09/27/08 09:10 AM
09/27/08 09:10 AM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I used an EZ wiring harness for my 36 Plymouth.Bought online for about $165. Easy to install and modify if I needed to.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: What wiring harness are you other rodders using? [Re: 36PLYM] #126638
09/30/08 10:21 PM
09/30/08 10:21 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Check out centech.com
Absolute top of the line kit's designed by an actual electrical engineer,
I use them EXCLUSIVELY
for street rod type harnesses
Tim
Re: What wiring harness are you other rodders using? [Re: NoFrills] #126639
10/01/08 01:57 AM
10/01/08 01:57 AM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
I prefer the ones that don't use a bulkhead...lots easier to make a clean installation (hide everything) with the "cheap style".
I bought an EZ Wiring kit from ebay for something like $115. It has worked great so far.
Re: What wiring harness are you other rodders using? [Re: Flipper1938] #126640
10/01/08 10:01 AM
10/01/08 10:01 AM
Rosedale B.C Canada.. Eh
Fargo Freek Offline
super gas
Fargo Freek  Offline
super gas
I used a Keep it clean wire kit very easy to install and all the wires are labeled
www.keepitcleanwiring.com
Re: What wiring harness are you other rodders using? [Re: Fargo Freek] #126641
10/06/08 11:26 PM
10/06/08 11:26 PM
restos just aren't my thing
gtsuperbee Offline
gtsuperbee  Offline
I am using a ronfranciswiring.com kit in a customer's car.
Restoring a car to look "only" as good as the factory made it is like getting a boob job for your wife and having the doctor make them two different sizes to seem more natural
Re: What wiring harness are you other rodders using? [Re: Flipper1938] #126642
10/07/08 10:39 PM
10/07/08 10:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
When I did my 38 I used the wiring harness from a donor car (79 Newport). Car cost me $100, got a good running 360, trans, rear end, wiring, you name it. I stripped that car for everything I could and scrapped it for $50.
Can't get much cheaper than that and the former owner delivered it to my house for that price too.
Don't be the exception.
Re: What wiring harness are you other rodders using? [Re: Supercuda] #126643
10/08/08 06:24 AM
10/08/08 06:24 AM
places
79powerwagon Offline
places
Kwik-Wire. As an added bonus, they are about 40 minutes from my house!
Re: What wiring harness are you other rodders using? [Re: 79powerwagon] #126644
10/14/08 11:02 PM
10/14/08 11:02 PM
Oklahoma City, OK
moposcar Offline
moposcar  Offline
Oklahoma City, OK
Great post guys. I was coming on here to ask the same question. I need wiring for the 56 and was looking at Painless wiring. Seemed easy enough, but I didn't understand why they do it for the GM tilt steering, and other options. No mopar stuff. I couldn't find what would work best for my application.
Re: What wiring harness are you other rodders using? [Re: moposcar] #126645
10/14/08 11:15 PM
10/14/08 11:15 PM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
Most aftermarket steering columns (Ididit and such) used in streetrods are GM style.
My harness was designed for a GM column, but I tweeked it for use with a seprate ignition switch and an old accessory turn signal switch.
Re: What wiring harness are you other rodders using? [Re: moposcar] #126646
10/15/08 09:13 AM
10/15/08 09:13 AM
E
earlymopar Offline
earlymopar  Offline
E
Keep in mind that many of the tilt columns used in Mopar products are made by Saginaw and therefore are indentical to GM in many aspects. The tilt columns I have from a Chrysler and 81 Dodge pickup were both made by Saginaw and I used a GM tilt column repair manual to dismantle them.
- EM
Re: What wiring harness are you other rodders using? [Re: earlymopar] #126647
11/04/08 03:40 AM
11/04/08 03:40 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
GM ownes the patent on tilt,,most columns are tilt these days thats why most are geard to GM,,
im also trying to decide what after market wiring to use in my 66, then ill use the same in my 40,a complete kit with all the relays,is costly,,almost 600.00 bucks from ron francis,,that is the kit ide like to use,but a hard price to swollow,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: What wiring harness are you other rodders using? [Re: bohmer2] #126648
03/07/09 08:59 AM
03/07/09 08:59 AM
Thanks for the props guys. If anyone needs info on our Rebel Wire harnesses, please let me know. 618-395-8216.
Glenn
Re: What wiring harness are you other rodders using? #126649
03/07/09 01:09 PM
03/07/09 01:09 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
GREAT! Now I know where my next 5 paychecks or so are going...Do I get a bulk discount Glenn?
2 Demons...no, not my kids!
Re: What wiring harness are you other rodders using? [Re: NoFrills] #126650
03/07/09 01:12 PM
03/07/09 01:12 PM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
...run the wires through a hole...
Something to consider for future maintenance. I did a complete re-wire on a friend's '60 El Camino. Took my time and ran the wires low and out of sight. Used existing hole on the core support and wired it all up nice and pretty. Then he decided to replace the core support and they just cut the wiring off. Guess who's going to get called to fix it when they are done?
Cheeto
It's not perfect.
It's not correct.
It's not yours!
