833 4 spd wont shift into 2nd gear ? #1266216
07/12/12 12:34 AM
07/12/12 12:34 AM
USA
K
krw71ragtop Offline OP
K
USA
Under normal shifts it will go into all gears. But at wide open throttle in 1st gear, I'll let off the gas, push the clutch, pull shifter to 2nd but it wont go. It will go to 4th or 3rd though.
I had the side cover off last winter to replace a leaky gasket. Could this be a rod adjustment problem and if so which rod ? Or did I mess something up when I pulled the cover ?
Re: 833 4 spd wont shift into 2nd gear ? [Re: krw71ragtop] #1266217
07/12/12 08:15 AM
07/12/12 08:15 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Did it shift fine before you pulled the cover? Usually the cover realigns because of the shouldered bolts. You can try loosening the cover and taping it upwards then retighten. Otherwise Id say the syncro is going bad.
I am truckless..
Re: 833 4 spd wont shift into 2nd gear ? [Re: 340SHORTY] #1266218
07/12/12 09:20 AM
07/12/12 09:20 AM
USA
K
K
USA
It shifted fine before the cover was off. New trans with Passon Performance overdrive gear set.
Re: 833 4 spd wont shift into 2nd gear ? [Re: krw71ragtop] #1266219
07/12/12 11:50 AM
07/12/12 11:50 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Did the gearset including new syncro assemblies ? What fluid ?
Re: 833 4 spd wont shift into 2nd gear ? [Re: JohnRR] #1266220
07/12/12 09:48 PM
07/12/12 09:48 PM
USA
K
K
USA
Yes ! Valvoline 75W90
Re: 833 4 spd wont shift into 2nd gear ? [Re: krw71ragtop] #1266221
07/12/12 11:05 PM
07/12/12 11:05 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You didn't by chance take the plug out of the bottom for the reverse idler detent did you? This happened to me and mine would not go into second after a hard launch. The ball come off of the spring in the detent and when this happens it lets the reverse idler slide forward freely and basically block the fork to allow second gear.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 833 4 spd wont shift into 2nd gear ? [Re: 71yelladustr] #1266222
07/12/12 11:25 PM
07/12/12 11:25 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I agree, if that ball comes out you will never get it in second gear at WOT.
Re: 833 4 spd wont shift into 2nd gear ? [Re: 71yelladustr] #1266223
07/12/12 11:49 PM
07/12/12 11:49 PM
USA
K
K
USA
There is a plug I pulled out on the drivers side, rear, bottom to check if all the fluid was drained out. I had drained it earlier last winter and forgot I did. But I did not see a ball or a spring in the plug that I pulled out.
This is my first 4 spd car so I'm learning slow but sure and appreciate all the advice.
Re: 833 4 spd wont shift into 2nd gear ? [Re: krw71ragtop] #1266224
07/12/12 11:55 PM
07/12/12 11:55 PM
Missouri U.S.A.
Missouri U.S.A.
That plug should contain the spring and steel ball. Maybe yours was missing all along. Easy way to tell if is gone is to pop of your reverse rod at the trans and move the lever into reverse. You should be able to feel the detent working to hold the reverse idler. Meaning it should lock and stay into posistion. If it moves freely both ways, you have most likely found your problem.
10.02@134
Re: 833 4 spd wont shift into 2nd gear ? [Re: 71yelladustr] #1266225
07/13/12 12:28 AM
07/13/12 12:28 AM
USA
K
K
USA
I unhooked the rod and when I pull the lever foreward I can feel tension until it clicks or shifts into reverse.
Re: 833 4 spd wont shift into 2nd gear ? [Re: krw71ragtop] #1266226
07/13/12 11:43 AM
07/13/12 11:43 AM
JohnRR Offline
JohnRR  Offline
the plug they are talking about is on the rear of the case under the reverse light switch , it goes in at an angle , if you can feel the detent when shifting it wit hthe shift arm removed the ball is in place ...
Here's a novel idea .... CALL PASSON, his gearset and syncros. Did you use the fluid he specified ???
Re: 833 4 spd wont shift into 2nd gear ? [Re: JohnRR] #1266227
07/13/12 01:06 PM
07/13/12 01:06 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I know it was mentioned earlier in the thread, but if you didnt loosen the cover-tap it upward and retighten it, then you should. Most common cause. If that reverse lever takes some effort to move forward and back-then the ball is there.
If that doesn't work, then take the side cover off and see if you can easily move the slider into second. These transmissions are very uncomplicated. The answer is right under your nose...
MB
