E-body engine wiring and MSD #1265649
07/11/12 10:17 AM
07/11/12 10:17 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Question:
Putting together my friend's '71 Challenger R/T. He has bought all new harnesses.. He purchased the engine harness that incorporates the Chrysler-electronic ignition. But, he's planning to install MSD on it. Soooo, should he have a regular harness or will I be able to used the Electronic-version and just go ahead and install?
Troy
Houston Mopar Connection Club
Re: E-body engine wiring and MSD [Re: hemi68charger] #1265650
07/11/12 10:27 AM
07/11/12 10:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Regular harness would be better or you could gut the Chrysler box and wire a hidden MSD unit thru it leaving a stock appearance under the hood , should the owner want a stock appearance ...
What distributor is he using? If stock electronic I do the hidden thing myself .
Re: E-body engine wiring and MSD [Re: JohnRR] #1265651
07/11/12 11:05 AM
07/11/12 11:05 AM
Houston, Tx
Houston, Tx
John, he's using the MSD unit, he purchased the complete kit.. I will attempt to make things as OEM as possible. I'm pretty good with creating OEM-looking harnesses if I have to. And yeap, that ballast resistor has to go (put back into an original place and version)..
Troy
Re: E-body engine wiring and MSD [Re: hemi68charger] #1265652
07/11/12 11:12 AM
07/11/12 11:12 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I mean no offense, but if thats the engine compartment in question.
why bother hiding anything ?
Re: E-body engine wiring and MSD [Re: gtx6970] #1265653
07/11/12 12:11 PM
07/11/12 12:11 PM
Houston, Tx
Houston, Tx
Yes, that's Hoss' car. If we can hide the huge red MSD box, we will try. Right now it is mounted under the battery tray. If I have to create a harness for the MSD ignition, I'll make it as OEM-looking as possible (proper wrap and terminal connectors).
Troy
Re: E-body engine wiring and MSD [Re: hemi68charger] #1265654
07/11/12 01:51 PM
07/11/12 01:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Absolute waste of effort but that's your choice, a stock looking harness is going to be lost in that engine bay. Trade in the electronic harness for a points harness or put that on the shelf and buy another.
Since it was you that was asking the question ... in the restoration section no less ... I just ASSuMEd a stock engine bay.
Re: E-body engine wiring and MSD [Re: JohnRR] #1265655
07/11/12 03:07 PM
07/11/12 03:07 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I thought they made an MSD box that used the stock Chrysler electronic connector.
Or did someone tell me a fib?
Re: E-body engine wiring and MSD [Re: Morty426] #1265656
07/11/12 03:30 PM
07/11/12 03:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No they DID , it's not available NEW anymore that I have seen.
Re: E-body engine wiring and MSD [Re: Morty426] #1265657
07/11/12 03:34 PM
07/11/12 03:34 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
hide the mad box under the battry tray.
connect the blue wire and the black wire lading to the ballast resistor. then use those connected wires for your keyed power lead for the msd.
then hide the 2 wires for the coil wires in the original harness back into the harness.
then hide the coil leads from the msd into the original harness.
install all of the original ignition components on the firewall.
your msd now works the ignition system without sticking out like a sore thumb.
if your msd ever fails you re connect the black and blue wires to the ballast. then attach the original coil wires to the correct terminals and now your original electronic ignition system will now work.
here is what it will look like.
unless someone looks under the battry tray and sees the red msd box, they will never know you are using a msd ignition system.
perception is 90% of reality
Re: E-body engine wiring and MSD [Re: Mr T2U] #1265658
07/11/12 04:48 PM
07/11/12 04:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That would work if he had a MP distributor very nicely.
Re: E-body engine wiring and MSD [Re: Mr T2U] #1265659
07/11/12 05:22 PM
07/11/12 05:22 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
An MSD system should not share any of the vehicles OEM harnesses. I make my own dedicated MSD harness that shares nothing with the original wiring and mount the box under the back seat which is much cooler than the motor compartment. If you want to access the box, just lift the seat up-no tools needed. Clean and never any problems. This is an example of a car I did that has the hidden componentry.
Yes, the coil is an MSD coil ...The radio suppressor is just for show.
MB
Re: E-body engine wiring and MSD [Re: HPMike] #1265660
07/11/12 06:32 PM
07/11/12 06:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Mike , who lettered up the coil , I have an epoxy filled MSD I'd like to have done
Re: E-body engine wiring and MSD [Re: JohnRR] #1265661
07/11/12 06:41 PM
07/11/12 06:41 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
John Grinwald... Its been a few years, I am not sure if hes still in the game..I would think that Dave Patik(Performance car graphics) could do it as well??
MB
Re: E-body engine wiring and MSD [Re: hemi68charger] #1265662
07/11/12 08:51 PM
07/11/12 08:51 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Troy,
no dis-respect but I fail to see the point of going thru the trouble of 'hiding anything'.
The aftermkt valve covers, headers and that glaring red MSD distributer kind of sticks out like a sore thumb don't ya think.
I put it under the battery tray more for an out of the way/ in an air stream to keep it cool sort of thing. Yet easy access to change the rpm chip if needed as opposed to hiding it.
Re: E-body engine wiring and MSD [Re: gtx6970] #1265663
07/11/12 08:56 PM
07/11/12 08:56 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm guessing this car had considerably more ommmmph than what your working on . So sneaking up on anyone simply wasn't going to happen with this car.
This is well over 700 hp and darn near 500 cu in
Re: E-body engine wiring and MSD [Re: gtx6970] #1265664
07/11/12 09:22 PM
07/11/12 09:22 PM
Houston, Tx
Houston, Tx
??? Don't get that comment John? Restorations don't have to have 100% OEM correct parts. I'm asking a simple question of whether or not I can utlize the new harness he has (with electronic adaption) and intergrate MSD into... For the record, he's going to have an aftermarket radio in the glove box......
Whatever I do, I going to make it look as good as possible. Where ever I can get away with making it look as factory as possible, I will. I did suggest to him running a Pertronix Ignitor II in it, we'll see.
Thanks everyone for your suggestions on time management. And Roy I'll read over your input a little more............
I'll have it look nice and the way he wants..
Cheers,
Troy
