Torqueflite 727 question??? #1265450
07/10/12 11:23 PM
07/10/12 11:23 PM
Texas
mkbubs Offline OP
mkbubs  Offline OP
Texas
i am wanting to put an aftermarket shifter in my car, B&M, Hurst kind of thing. i dont want shifter for the strip, what im looking for is one for the street. Something that is not real agressive. Any ideas on what kind of shifter i should look at? Any help would be greatly appreciated,thanks.
Re: Torqueflite 727 question??? [Re: mkbubs] #1265451
07/10/12 11:32 PM
07/10/12 11:32 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
There are a lot of basic shifters made by Hurst, B&M and others. Jegs and Summit will carry what you need. I don't know what you mean by agressive but it sounds like you want to stay away from ratchet shifters etc. B&M sport or Hurst promatic are good inexpensive shifters.
Re: Torqueflite 727 question??? [Re: mkbubs] #1265452
07/11/12 12:08 AM
07/11/12 12:08 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I tossed a B&M QuickSilver shifter into my M-body...it's a ratchet when needed..otherwise, it stays in D.
Re: Torqueflite 727 question??? [Re: mkbubs] #1265453
07/12/12 06:48 PM
07/12/12 06:48 PM
NE
bigtail Offline
bigtail  Offline
NE
Curious why you want an aftermarket shifter? Some people swear by them. Some people swear at them. Have you seen the threads on cable routing, cable lentgh, and getting shifter aligned? Food for thought. Good luck.
This page is made up completely of recycled electrons.
Re: Torqueflite 727 question??? [Re: mkbubs] #1265454
07/12/12 06:57 PM
07/12/12 06:57 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
what is this going in? are you looking for old skool looks or more modern? as stated above, whats wrong with something stock?
Re: Torqueflite 727 question??? [Re: bigtail] #1265455
07/12/12 07:08 PM
07/12/12 07:08 PM
scratchnfotraction Offline
AMEN! brother. I still have not got the hurst promatic shifter adjusted dead on yet and will be going back to the stock colum shifter on my 88 440 truck.
I like the 4-speed t-handle look of it,like how it works,but what a PITA! for me to get adjusted. seems to have a 1/8" play in the cable itself that I can get to shift down good but not upshift good or vise-versa
Re: Torqueflite 727 question??? [Re: scratchnfotraction] #1265456
07/14/12 08:55 AM
07/14/12 08:55 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Often its that the throw of the shifter does not equal the throw of the trans lever. The length of the shift lever on the trans could vary.
Re: Torqueflite 727 question??? [Re: CYACOP] #1265457
07/14/12 01:12 PM
07/14/12 01:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Most shifters come with a matching trans lever.
Re: Torqueflite 727 question??? [Re: stumpy] #1265458
07/14/12 05:06 PM
07/14/12 05:06 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
There are about of 4 of us here that have about 15 + years on the Pro-matics with absolutely 0 problems. Never had a any problems getting adjusted either.
Re: Torqueflite 727 question??? [Re: mkbubs] #1265459
07/15/12 03:36 PM
07/15/12 03:36 PM
Commack NY USA
2
2Red2LoudDodge Offline
Commack NY USA
Replaced a B&M ratchet shifter after the cable melted four times from stop and go summer driving. Installed a Lokar floor mount shifter that uses mechanical linkage. Looks old school when combined with same boot and trim ring used on a non console shifted '68 Mopar. Can't attach pictures but will gladly email if interested.
