converter change improvement guess ? #1265352
07/10/12 09:23 PM
07/10/12 09:23 PM
arizona
HP318 Offline OP
HP318  Offline OP
arizona
69 coronet, low gear 904, 13.27@102.7 1.96 sixty foot with stock converter stalls at 2500 ultimate converter {on order} 4200 aprox stall, weight 3450 with driver 4.10 detroit locker, 275/60 R15 MT ET streets, What do you think?
Re: converter change improvement guess ? [Re: HP318] #1265353
07/11/12 02:26 AM
07/11/12 02:26 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
you're gonna have to give some info on the motor. But there are so many variables in this equation, that anything here is gonna be purely a guess. I recently went from a budget 11" ACC 3500 converter, to a custom made Lupo Dynamic 9-1/2", and enitial passes would suggest I picked up over a tenth in 60', and a few tenths in E.T.
Only way to find out is gonna be to make passes.
Re: converter change improvement guess ? [Re: StealthWedge67] #1265354
07/11/12 08:25 AM
07/11/12 08:25 AM
arizona
HP318 Offline OP
HP318  Offline OP
arizona
thanks for repling,cam-mopar p4452759 lift-430/450 adv duration 260-268-44 separation 110 C/L 105 advanced 3*,heads 69 318 1.88/1.60 home ported,performer intake crossover pluged,850 T/Q,sealed 6 pack scoop,windage tray &valley pan,273,rockers,headman 1 5/8 headers,2 1/2 pipes super turbo mufs,undersize crank pulley, thanks,forgot,heads milled .060 thin gasket,9 1/2 comp
Re: converter change improvement guess ? [Re: HP318] #1265355
07/11/12 09:07 AM
07/11/12 09:07 AM
gregsdart Offline
gregsdart  Offline
If the stall comes back at a true 4200 the ET and 60 ft reduction is going to be very good. How much is up to debate, but my WAG is .3 to .5,plus maybe some mph. Instead of 150 hp at the launch you will have what ever it makes at 4200 minus some loss for slippage. So it will pull that much harder all the way to when the car would have reached 4200 rpm with the old converter. Please post results when you can.
Re: converter change improvement guess ? [Re: gregsdart] #1265356
07/11/12 11:46 AM
07/11/12 11:46 AM
Puyallup, WA
Puyallup, WA
4200 sounds like a lot of flash for an essentially stock 318 with a mild cam. I'd get ahold of a converter company (I had a great experience with Shaun @ Dynamic, but I've heard Lenny at Ultimate is as good as gold also) and talk to them about what you want and what you have.
Re: converter change improvement guess ? [Re: StealthWedge67] #1265357
07/11/12 02:10 PM
07/11/12 02:10 PM
NC USA
U
ultimatelenny Offline
U
NC USA
4200 is a prorated number. The customer is located in Arizona with a lot of heat and thin air factored into the selection also. This as well as all the specs on his combo was gone over in great detail before a selection was made. The 318 has a 3.31 stroke and notoriously low on low end torque, therefore you would want to have the loose enough to get into the torque of the engine as well as having good lockup capabilities. I very confident this customer is well on his way to a substantial improvement all the way around.
Lenny Croteau www.ultimateconverter.com Phone 704-892-6837 Fax 704-892-6880
Re: converter change improvement guess ? [Re: ultimatelenny] #1265358
07/11/12 02:28 PM
07/11/12 02:28 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would venture .5 with better launch and then better shift recovery.
maybe more!
Re: converter change improvement guess ? [Re: HP318] #1265359
07/11/12 03:45 PM
07/11/12 03:45 PM
Peoples republic of clackamas ...
atoetly Offline
atoetly  Offline
With one of Lennys converters expect a huge performance gain.
Re: converter change improvement guess ? [Re: atoetly] #1265360
07/11/12 08:54 PM
07/11/12 08:54 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
4,200 sounds right on the money to me.. if it doesn't spin the tires or run out of fuel on the top end, I figure it'll run 12.60's-12.80's...
If you can't handle the truth, you're living a lie.......
Re: converter change improvement guess ? [Re: Big Squeeze] #1265361
07/12/12 09:30 AM
07/12/12 09:30 AM
ill
dennismopar73 Offline
ill
It is real hard to guess sounds as if a little N20 is involved as well, ??
Re: converter change improvement guess ? [Re: dennismopar73] #1265362
07/12/12 09:39 AM
07/12/12 09:39 AM
arizona
HP318 Offline OP
HP318  Offline OP
arizona
thanks for the compliment....its N/A
Re: converter change improvement guess ? [Re: ultimatelenny] #1265363
07/12/12 10:21 AM
07/12/12 10:21 AM
gregsdart Offline
gregsdart  Offline
Lenny, would a converter set up for this combo work OK with a 3.73 gear and 28 inch tires? Mostly street, need decent lockup at cruise of 60 to 65 mph and able to keep it cool with a big trans cooler.
Re: converter change improvement guess ? [Re: gregsdart] #1265364
07/12/12 12:40 PM
07/12/12 12:40 PM
NC USA
U
U
NC USA
I would think so. Depending on the whole combo and your data, you could configure this particular converter to work around your preferences.
Re: converter change improvement guess ? [Re: ultimatelenny] #1265365
07/12/12 02:09 PM
07/12/12 02:09 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
My guess would be low 13.00s. I'm just guessing around 3500 pounds, which means about 300 hp. I don't see it picking up more than a tenth and a half in the sixty foot. Peak torque with that cam can't be above 3200rpm...even in a 318. The cool thing is that you could through a bigger cam at it with the new converter!
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
