cometic bore size ???? need help #1265341
07/10/12 09:18 PM
07/10/12 09:18 PM
nc
E
earthmover Offline OP
E
nc
ok guys i ordered my new cometic head gaskets for my 451 build..the bore size i ordered was 4.380 the block is 4.375...they sent me 4.410 should i send these back or will they be fine???? new to this big block stuff and this type of build....thanks mike
Re: cometic bore size ???? need help [Re: earthmover] #1265342
07/10/12 10:08 PM
07/10/12 10:08 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
i'm not sure on there reasoning. when i ordered my 4.500 bore they said to run the 4.530 gasket. so i did. everything's fine.
Re: cometic bore size ???? need help [Re: Deepockets] #1265343
07/10/12 10:16 PM
07/10/12 10:16 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Thats funny.. Just today I got my Cometics.. 4.500 bore and they sent me 4.540...
Re: cometic bore size ???? need help [Re: earthmover] #1265344
07/10/12 10:18 PM
07/10/12 10:18 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
they probably saved you the hassle of finding out the 4.38 gaskets wouldn't fit because they overhang the bore or combustion chamber. 4.38 only leaves .0025" per side for tolerances and normally chrysler blocks have a pretty heavy chamfer at the top of the bore. even with the 4.41 that's only .018 per side, put them on and go on your way
Re: cometic bore size ???? need help [Re: jamesc] #1265345
07/10/12 10:21 PM
07/10/12 10:21 PM
jamesc Offline
jamesc  Offline
we'd all like to have gaskets that perfectly fit the bore but that's not the reality of tolerances. bore chamfer, dowel pin location, bore location, combustion chamber location and size, think about it. you need a margin with this stuff unless you're going to precisely locate and machine all of these dimensions.
Re: cometic bore size ???? need help [Re: earthmover] #1265346
07/10/12 10:28 PM
07/10/12 10:28 PM
Delray beach, Florida
P
Performance Only Offline
P
run them. that's what i would've sent you also. they did you a favor by giving you a little room. you don't want the gasket the same as the bore size.
machine shop owner and engine builder
Re: cometic bore size ???? need help [Re: earthmover] #1265347
07/10/12 10:32 PM
07/10/12 10:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With the chamfer on top of the bore its much bigger
Re: cometic bore size ???? need help [Re: MR_P_BODY] #1265348
07/10/12 10:44 PM
07/10/12 10:44 PM
nc
E
E
nc
thanks guys. also would like to add not a bash just asking as i am new to this..mike
Re: cometic bore size ???? need help [Re: earthmover] #1265349
07/10/12 11:04 PM
07/10/12 11:04 PM
NC
440Jim Offline
440Jim  Offline
NC
For the bore size you ordered, that is a reasonable size gasket. I have a 4.375" bore and I run 4.440" Cometics because the 1978 Chrysler factory put a chamfer on the top of the bore the size of the rings of Saturn...
Don't send them back for smaller gaskets!
Re: cometic bore size ???? need help [Re: earthmover] #1265350
07/11/12 12:08 AM
07/11/12 12:08 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
You NEED an extra .030-.060 extra above and beyond the actusl bore size. Run em.
RIP Monte Smith
Re: cometic bore size ???? need help [Re: CompWedgeEngines] #1265351
07/11/12 12:30 AM
07/11/12 12:30 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i'v been told to run .030 bigger on gasket bore than the cylinder bore.
