Re: Help me pick some carbs for 572 HEMI
[Re: Bishop]
#1265301
07/10/12 09:06 PM
07/10/12 09:06 PM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
You have the best or one of the best in your home state. Love his stuff; Dale Cubic of CFM. http://cfmperfcarbs.com/
"Any fool can know. The point is to understand"
- A. Einstein
[Re: EvilB1Dart]
#1265302
07/11/12 11:14 AM
07/11/12 11:14 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
The original crossram carbs were vacuum secondary but I don't guess you have to run them that way. I think you can still buy the original new 4235/4236 Holleys for about $750 each.
2011 Drag Pak Challenger
[Re: AndyF]
#1265304
07/11/12 01:02 PM
07/11/12 01:02 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
A pair of HP 950's would really wake that big motor up!
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Bishop]
#1265306
07/11/12 01:58 PM
07/11/12 01:58 PM
Posts: 31,050 Oregon
AndyF
My recommendation would be a pair of the new all aluminum Holley carbs. You'll save a bunch weight and they are fully adjustable. Most people don't even understand all the new adjustment capabilities on the new Holley carbs since they haven't been out very long. The new carbs are so much better than anything in the past that there just isn't much reason to use anything else anymore unless the rules require it.
Size is a little tougher choice, a pair of 750 carbs would probably be my choice.
If you're comfortable with carb tuning and have a wide band setup on the car then I'd recommend just buying a pair of new aluminum 750's from Summit and bolting them on. If you don't want to mess with tuning then give a carb tuner a call and have them tweak a pair of carbs for you. BLP is who I work with but there are other tuners out there.
If you are a really super serious racer with a big checkbook then call someone like Braswell and have them build you a pair of carbs. But I wouldn't spend that kind of money unless I had a racepak on the car and I could tell Braswell exactly what the car is doing at each gear change going down the track.
I've dyno tested super expensive Braswell carbs back to back against the new Holley aluminum carbs and there isn't a difference on the dyno. But, that doesn't mean that a Braswell won't get you down the track faster. There is a lot of stuff going on during the gear changes and such that you don't see on the dyno.
The cross ram is a bit of an issue for carb tuners. You might have to call around a bit before you find someone who knows what works on those things. A really serious setup would require O2 bungs in each pipe. If you aren't that serious then just jet it a little rich and go have fun.
[Re: EvilB1Dart]
#1265308
07/15/12 02:13 PM
07/15/12 02:13 PM
Posts: 288 no mans land
racerbychoice
no mans land
^^^^^this^^^^^
the best advice so far. call him you will not be sorry. plus you get unlimited service after the sale. you buy one of dale's carbs, you buy him too. plenty of hemi experience.
nhra/ihra pro stock, sportsman and serious headsup racers don't use this guy for nothing. right up there with braswell, gary williams and bob book racing carbs, if not better.
dj
[Re: AndyF]
#1265310
07/15/12 08:57 PM
07/15/12 08:57 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I suggest giving Quick Fuel a call and talk to them about your combination. They are good people.
Gone to the dark side with an LS3 powered '57 Chevy 210
