I am working on fixing my superbee and was wanting advice on how to deal with the rust in the 1/4 extension area. (see pic below) Should I remove the spot welds and peel the tail light surround away from the 1/4 panel and then weld in two new pieces? Just cut out what I see and weld in new pieces? Find some replacement pieces? I need ideas. Thanks.
This space left intentianlly blank.
