E-body After market Air, Ease of Install & who's best
#126442
09/26/08 10:45 AM
09/26/08 10:45 AM
Posts: 445 Fairfield, Ohio
holtzdog55
Fairfield, Ohio
Just after some opinions on After market Air for e-bodies. Who has installed a system or kit and who was the manufacturer. Was it an easy or tough install???? ![](/ubbthreads/images/graemlins/shruggy.gif) Just doing some homework before I decide..... ![](/ubbthreads/images/graemlins/drinking.gif) Thanks Moparts, Tony
Finally Done....BEERS!!!
Re: E-body After market Air, Ease of Install & who's best
[Re: Challenger 1]
#126444
09/26/08 06:05 PM
09/26/08 06:05 PM
holtzdog55
Fairfield, Ohio
Alot of questions come up...... Originally non-air car heater box only. Classic Auto Air which I was thinking about makes a kit that fits e-bodies and doesnt use original heater box, so I wouldn't have to redo it...kit goes for $1299 everything included lines/heater core/condensor/etc/etc. http://www.classicautoair.com/EBody7074.aspWould this be the way to go? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Challenger 1]
#126446
09/26/08 06:34 PM
09/26/08 06:34 PM
holtzdog55
Fairfield, Ohio
I talked to one of the guys in Texas and he said it can be done easily in a weekend....they will do it in 1/2 day for 1,350.00....ha, ha! Was just trying to see if anyone here did one on their own and how it went...hopefully someone will come forward with a story.... ![](/ubbthreads/images/graemlins/beer.gif)
[Re: holtzdog55]
#126447
09/26/08 06:46 PM
09/26/08 06:46 PM
Challenger 1
Cincinnati, Ohio
I'm sure someone around here has done it and will speak up.
$1350. for complete install and 134 charge,belts,pulleys,wiring and running ready to use is a pretty fair deal, if you ask me.
[Re: holtzdog55]
#126448
09/26/08 06:49 PM
09/26/08 06:49 PM
Andrewh
I did it in an early b. So I had to use the universal kit. Plus I made it harder and had a poly 318.
It took 2 weekends to do it. Got everything mocked up in the engine compartment, and took it to a local shop to cut and crimp the lines. Then had a plate welded to bolt the new box to, with studs that bolted where the orignal heater box bolted to.
I did not use the stock controls. I removed them and put in the electric controls, so I don't know how hard it is to get the stock heater controls working. I do know that it is backwards. Heat on the slider is for cold and cold is for heat, so I opted for the electric controls.
The hardest part for me was getting the compressor lined up, but for an engine they make the kit for, it should be a bolt in. They supply a pulley that bolts infront of the crank pulley, and everything runs belts to that.
It would be nicer if you could find an a/c donor motor for all the brackets and pulleys so you don't have to use much of their motor mounting stuff and make it cleaner looking, but you do need their plate(at least sb wise) for it to bolt to.
Inside I image the a/c box is the same, just mounting hardware is different. It is a lot smaller than the 66 and up a/c boxes. It was smaller than the 65 heater only box, and that is about half the size of the 66 and up a/c box.
There are several people that found a/c dashes and mounted stuff to it. I chose just to hang the vents under the dash.
[Re: holtzdog55]
#126450
09/26/08 10:47 PM
09/26/08 10:47 PM
Challenger 1
Cincinnati, Ohio
Thats 1350.00 Plus the cost of the kit 1299.00 ![](/ubbthreads/images/graemlins/haha.gif)
I know... If you drove into their shop with a non AC running car and they took out the dash and cut and fit AC vents a and run the duckwork. Then then would replace and fit the new box run all the electric/cables. Then put it all back togeather is alot of work right there in the interior alone.
I know yours is apart and it's not the same thing as above, really when you think about counting all the work up front too. 1350 aint bad labor charges which includes freon and belts and stuff like that.
Good luck with your car, we got hookup one of these days.
[Re: Challenger 1]
#126451
09/28/08 12:33 PM
09/28/08 12:33 PM
holtzdog55
Fairfield, Ohio
Another question..... Do I have a Heater only box or an A/C box??? How can you tell the difference?? The reason I'm asking is when I took it apart there is a large foam piece that isnt in the kit I got from Detroit Muscle..... ![](/ubbthreads/images/graemlins/confused.gif)
[Re: holtzdog55]
#126452
09/28/08 12:33 PM
09/28/08 12:33 PM
holtzdog55
Fairfield, Ohio
another pic...
[Re: holtzdog55]
#126453
09/28/08 12:34 PM
09/28/08 12:34 PM
holtzdog55
Fairfield, Ohio
[Re: holtzdog55]
#126458
09/28/08 02:11 PM
09/28/08 02:11 PM
Posts: 4,757 Florida
BDW
[Re: holtzdog55]
#126459
09/28/08 02:28 PM
09/28/08 02:28 PM
Challenger 1
Cincinnati, Ohio
If anyone is interested in this A/C box(was going to put in new foam but got the wrong kit), Let me know or make an offer.
It looks like you got to keep it now, to go with your AC equipped firewall car.
For sale ads are frowned upon in Q&A.
"Polar Bear" is where I found a new evaparator for my challenger AC box. FYI ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: BDW]
#126460
09/28/08 02:43 PM
09/28/08 02:43 PM
Posts: 4,165 Florida
cataclysm80
![](/ubbthreads/images/graemlins/iagree.gif) that is an AC firewall & you have an AC box. Just bolt it up, problem solved. Check the vacuum pods before installation. Mine leak at the shaft seal. Unfortunately no one makes a modern AC conversion kit for cars that already have AC. I'd love to have electronic actuated air blend doors instead of leaky shaft seals. Next step for you is to determine what you want underhood. engine/carb combo could affect this decision. Do you want V belts or serpentine? Do you want factory V compressor or Sanden? After figuring that out you just need to check if your missing any pieces, find them, and bolt it all together. Do you plan on using a rallye dash? Tav
[Re: Challenger 1]
#126461
09/28/08 02:44 PM
09/28/08 02:44 PM
cataclysm80
Wow! that's good info. Those are hard to come by.
Tav
